StarTech.com VGA to HDMI Adapter with USB Audio & Power-...
StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p
£37.39
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Supports video resolutions up to 1920x1080
  • Plug-and-play installation
  • USB powered
  • USB audio
  • Compact, lightweight design
  • Stock Status: In Stock
Product codes
Convert a VGA signal from a laptop or desktop to HDMI (USB-Powered). The VGA2HDU VGA to HDMI adapter lets you turn the VGA port on your Desktop or Laptop computer into an HDMI output port.
With the VGA2HDU, you can expand your VGA video output to accommodate the increasing number of displays and projectors that only support HDMI.
Not all VGA converters are created equal. This adapter ensures you're harnessing the highest video quality from your VGA output, with support for resolutions up to 1920x1080 (1080p).
For hassle-free setup the VGA to HDMI adapter allows for plug-and-play installation. Plus, with a built-in USB power cable the device is powered using the USB port on your computer. The VGA to HDMI adapter will work with any computer operating system, but when working with a Windows computer the adapter supports native USB audio, allowing you to add your computer audio to the HDMI signal.
Product Description StarTech.com VGA to HDMI Adapter with USB Audio - VGA to HDMI Converter for Your Laptop / PC to HDTV - AV to HDMI Connector (VGA2HDU) - video converter - black
Device Type Video converter
Max Resolution 1920 x 1080
Interfaces 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x HDMI output - 19 pin HDMI Type A
Dimensions (WxDxH) 3.5 cm x 26 cm x 1.5 cm
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com VGA to HD...
£37.39
