StarTech.com Video Wall Mount - Steel
£223.29
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Create an impressive video wall with this flat-screen TV mount, supporting a 45" to 70" display (anti-theft design)
  • Pop-out design extends up to 12" (306 mm) to give rear-screen access for display adjustment
  • 6 points of micro-adjustment (vertical, tilt and swivel) for exact display alignment
  • Type: Wall mount
  • Stock Status: In Stock
Product codes
Create a professional video wall, with fast and easy rear-screen access and display adjustment. This professional video-wall mount features an innovative pop-out design that enables fast and easy display alignment and adjustment, within a multi-display video wall.
Engineered with heavy-duty steel, the video-wall mount securely supports 45" to 70" displays, weighing up to 154 lb. (70 kg).
Using multiple VIDWALLMNT wall mounts, you can create an impressive video wall, enabling you to align your displays in unison. It's the ideal solution for public, business and commercial displays and includes an anti-theft feature (with padlock required).
With its unique pop-out design, the video wall mount helps you align your displays with perfect precision. Once installed, you simply press gently on the front of the display and the mount extends out from the wall for rear-screen access. This pop-out feature makes it easy to adjust the position and angle of the display, or replace a display when required.
The video-wall mount features 6 points of micro-adjustment, with vertical, tilt and swivel adjustments, to provide exact display alignment and an optimum viewing angle. You can tilt your display +3° / -5°, adjust the swivel angle +1.2° / - 1.2°, and rotate the display +3° / - 3°. The video-wall mount also features lateral shift brackets, making it easy to move the display to the left or right for ideal alignment in your video wall.
This video-wall mounting system is designed for easy set-up and maintenance. The pop-out design also assists in installation and maintenance, plus a convenient kickstand allows you to tilt the display up to 12° giving you extra room when adjusting cables or accessing ports.
Product Description StarTech.com Video Wall Mount - For 45" to 70" Displays - Pop-Out Design - wall mount
Product Type Wall mount
Dimensions (WxDxH) 30.6 cm x 93.4 cm x 48.3 cm
Tilt -5°
Levelling -3° to 3°
Adjustments Levelling
Weight 15.7 kg
Recommended Use Video wall
Recommended Display Size 45"-70"
Max Mounting Pattern Size 600 x 400 mm
Max Load Weight 70 kg
Material Aluminium, steel
Colour Black
Package Content 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x20 screws, 4 x M8x30 screws, 8 x spacers (small), 6 x concrete anchors, 6 x 6.3x55 mm screws, hex key, 2 x adapter brackets, 4 x rectangular washers, wall plate, adjustment module, 2 x stoppers, 2 x plastic tabs, 4 x spacers (large), 6 x washers
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Video Wal...
£223.29
