StarTech.com Wall Mount Dual Monitor Arm
£173.36
Delivery:
Standard: 1-3 working days
Key features
  • Wall mount two 15“ to 24” monitors to save space
  • Adjust your monitors in unison, to keep your screens aligned
  • Mounting arm extends out from the wall up to 23" (585 mm), or tucks back to 6.5” (165 mm) from wall for a low-profile look
Product codes
Save space by mounting two monitors on your wall. This dual-monitor wall mount frees up space and creates a professional looking multi-monitor setup. Your two monitors move together to stay aligned. Simply extend the arm to place your monitors in the ideal position, or tuck them close to the wall when not in use. Plus, you can tilt, swivel and rotate your screens for optimal viewing.
The dual-monitor wall mount makes it easy to set-up two monitors in a business, commercial or office environment such as a health care or financial center. Both monitors are mounted on a single arm, so they move together in perfect unison, staying aligned at all times.
Using the mounting arm, you can extend your monitors up to 23" (585 mm) from the wall, so you can place your monitors for comfortable viewing. The arm also folds back in, so your monitors can be tucked just 6.5" (165 mm) from the wall when not in use, for a professional low-profile look.
Change the position and angle of your screens for ideal viewing. You can swivel your monitors up to 180°, and rotate up to 360° for landscape or portrait viewing. You can also tilt your monitors -15° to +15° to reduce glare and ensure a comfortable viewing position.
Made of steel, the dual-monitor wall mount securely supports two monitors, with a weight capacity of 11 lb. (5 kg) per monitor. It provides a stable setup for monitors up to 24".
Product Description StarTech.com Wall Mount Dual Monitor Arm - For Two 15"-24" Monitors - Steel - wall mount (adjustable arm)
Product Type Wall mount (adjustable arm)
Dimensions (WxDxH) 7 cm x 64 cm x 18.35 cm
Tilt -15° to 15°
Pan 180°
Rotation 360°
Adjustments Tilt, swivel, rotation
Recommended Use 2 monitors
Recommended Display Size 15"-24"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 10 kg
Material Heavy duty steel
Package Content Crossbar, 2 x VESA monitor mounts, 8 x M4x12 screws, 8 x M4x30 screws, 4 x washers, 4 x concrete anchors, 8 x spacers, hex key, 2 x plastic covers, 2 x cable-management clips, wall plate, 2 x mounting arms, crossbar cap, mounting arm retainer, 3 x M8x16 screws, 3 x mounting-arm washers, 2 x mounting-arm caps, wall plate retainer, level, 4 x M8x60 screws, crossbar retainer
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Wall Moun...
£173.36
