Free up space with this wall-mount monitor arm and enjoy optimum viewing with the long dual-swivel extension arm. The premium design ensures smooth, effortless motion and makes it easy to re-position your display, to work in comfort or collaborate with others. The attractive silver finish complements your decor.
The wall-mount system is ideal for business, healthcare, financial or other settings, where you may want to share your screen, or for customer-facing interactive displays.
The wall-mount monitor arm extends a full 20.4" (52 cm) and has three swivel points, offering an extended range of motion. Move the dual-swivel arms left or right, to change your screen position. You can also adjust the swivel tension.
The robust aluminum design provides a stable wall-mount for your computer monitor or flat-screen TV up to 30". It's ideal for touch-screen stability. The universal display wall mount supports VESA mount monitors (75x75, 100x100) up to 30.9 lb. (14 kg) in weight.
Share your screen with ease. The display wall mount offers a full +180-degree/-180-degree pan, to move your screen left or right. It tilts freely +90/-15-degrees, to adjust the angle up or down. Rotate your screen for landscape or portrait viewing.
Push the swivel arm back to the wall, so your monitor sits just 5" (129 mm) from the wall when not in use.
The quick slide-and-click connections make the monitor wall mount easy to assemble and saves time when setting up multiple units.
Product Description | StarTech.com Wall Mount Monitor Arm, Articulating Ergonomic VESA Wall Mount Monitor Arm, 20" (52cm) Long , Single 34" Display up to 30.9lb/14kg, Swivel/Tilt/Rotate, Adjustable Screen Mount - Cable Management clips (ARMWALLDSLP) - bracket - adjustable arm - for LCD display - silver | Product Type | Bracket (adjustable arm) - wall-mountable | Adjustable Depth | Up to 52 cm | Tilt | -15° to 90° | Pan | -180° to 180° | Rotation | 360° | Adjustments | Pan, tilt, swivel | Recommended Use | LCD display | Recommended Display Size | 13"-30" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 14 kg | Material | Aluminium | Colour | Silver | Package Content | Hex key, 4 x thumbscrews, 2 x mounting screws, 2 x monitor arms, 2 x wall plugs | Manufacturer Warranty | 2-year warranty |
General | |
Colour | Silver |
AV Furniture | |
Type | Bracket |
Design | Adjustable arm |
Placing / Mounting | Wall-mountable |
Cable Management | Integrated cable management |
Rotation | 360° |
Dimensions & Weight Details | |
Shipping Dimensions (WxDxH) / Weight | 13.9 cm x 17.8 cm x 33.9 cm / 1.9 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
