StarTech.com Wall Mount Monitor Arm-20.4" Swivel Arm up...
StarTech.com Wall Mount Monitor Arm-20.4" Swivel Arm up to 30" Monitors
£135.90
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Wall mount a VESA (75x75, 100x100) compatible display up to 34", flat screen, curved or ultrawide, with a max weight of 30.9 lb. (14 kg)
  • Long dual-swivel arm extends 20.4" (52 cm) and features three swivel points for flexible viewing
  • Easy tool-less assembly with quick slide-and-click connections
  • Adjust your viewing angle with +180°/-180° pan, +90°/-15°tilt, and rotation
  • Robust and stable aluminum design
  • Stock Status: In Stock
Product codes
Free up space with this wall-mount monitor arm and enjoy optimum viewing with the long dual-swivel extension arm. The premium design ensures smooth, effortless motion and makes it easy to re-position your display, to work in comfort or collaborate with others. The attractive silver finish complements your decor.
The wall-mount system is ideal for business, healthcare, financial or other settings, where you may want to share your screen, or for customer-facing interactive displays.
The wall-mount monitor arm extends a full 20.4" (52 cm) and has three swivel points, offering an extended range of motion. Move the dual-swivel arms left or right, to change your screen position. You can also adjust the swivel tension.
The robust aluminum design provides a stable wall-mount for your computer monitor or flat-screen TV up to 30". It's ideal for touch-screen stability. The universal display wall mount supports VESA mount monitors (75x75, 100x100) up to 30.9 lb. (14 kg) in weight.
Share your screen with ease. The display wall mount offers a full +180-degree/-180-degree pan, to move your screen left or right. It tilts freely +90/-15-degrees, to adjust the angle up or down. Rotate your screen for landscape or portrait viewing.
Push the swivel arm back to the wall, so your monitor sits just 5" (129 mm) from the wall when not in use.
The quick slide-and-click connections make the monitor wall mount easy to assemble and saves time when setting up multiple units.
Product Description StarTech.com Wall Mount Monitor Arm - Articulating/Adjustable Ergonomic VESA Wall Mount Monitor Arm (20" Long) - Single Display up to 34in (ARMWALLDSLP) - wall mount (adjustable arm)
Product Type Wall mount (adjustable arm)
Adjustable Depth Up to 52 cm
Tilt -15° to 90°
Pan -180° to 180°
Rotation 360°
Adjustments Pan, tilt, swivel
Recommended Use LCD display
Recommended Display Size 13"-30"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 14 kg
Material Aluminium
Colour Silver
Package Content Hex key, 4 x thumbscrews, 2 x mounting screws, 2 x monitor arms, 2 x wall plugs
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Wall Moun...
£135.90
