StarTech.com Wall Mounted Workstation - Extendable Dual Monit...
StarTech.com Wall Mounted Workstation - Extendable Dual Monitor Arm
£644.72
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Compact wall-mounted computer workstation for two monitors, with spring arms to adjust your monitor height with ease
  • Work in comfort with independent arms for dual monitors (up to 30" each) and keyboard
  • Extend the articulating monitor arms up to 25.6" (65 cm) from the wall, and keyboard tray up to 30.9" (78.4 cm)
  • Save space by folding the workstation close to the wall (monitor arms within 4.75", and keyboard tray within 3.5" of wall)
  • Optimize your viewing with tilt, swivel and rotate plus height adjustment along the pole
  • Stock Status: In Stock
Product codes
Increase your productivity, with a workstation that fits the way you work. Designed for a wide range of motion, this dual monitor wall-mounted computer workstation is easily adjustable with independent arms for your monitor and keyboard.
Move the wall-mounted sit-stand desk into position to work. Then push it back against the wall when not in use, folding the arms close to the wall. It's perfect for use in hospitals, clinics, warehouses, and other space-limited areas.
Extend the articulating monitor arms up to 25.6" (65 cm) from the wall. For ideal positioning, you can tilt or swivel your monitors, or rotate 360 degrees. The dual-monitor sit-stand workstation supports two VESA mount (75x75, 100x100) monitors up to 30", with a maximum weight of 19.8 lb. (9 kg) per display.
This wall-mounted height-adjustable desk enables a wide range of users to work in comfort. Adjust the height of both arms along the pole up to 17.5" (44.5 cm), plus the spring monitor arm has a height adjustment range of 10.6" (27 cm).
Place your keyboard where you need it, with an independent keyboard tray that extends up to 30.9" (78.4 cm) from the wall. Tilt the keyboard back to make sure your wrists are in a neutral position while typing. Place your mouse in the holder when not in use.
The modular design, with quick slide-and-click connections, makes installation easy and saves time when setting up multiple units.
Product Description StarTech.com Wall Mounted Computer Workstation - Premium - Dual Monitor - 13" to 30" - Articulating - Sit Stand Workstation - Silver (WALLSTSI2) - mounting kit
Product Type Mounting kit - wall-mountable
Mounting Components Pole, mouse holder, wrist rest, wall mount bracket, keyboard tray, 2 display brackets, 2 x spring arms, 2 x swivel arms with logo, monitor shoulder, wall mount bracket with lock plate, 2 x swivel arms, mouse tray, mouse tray fixed plate, EVA mouse pad
Dimensions (WxDxH) 72.2 cm x 74.2 cm x 123 cm
Tilt -15° to 90°
Pan -120° to 120°
Rotation 360°
Adjustments Height
Weight 14.2 kg
Recommended Use 2 LCD displays / keyboard / mouse
Recommended Display Size 13"-30"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 20.5 kg
Material Plastic, aluminium, steel
Colour Silver
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Wall Moun...
£644.72
