StarTech.com White Apple 8-pin Lightning Connector to Micro U...
StarTech.com White Apple 8-pin Lightning Connector to Micro USB Adapter for iPhone / iPod / iPad
£12.51
Colours:
Delivery:
Standard: 1-3 working days
Key features
  • Compact, portable design
  • All-white construction
  • Reversible lightning connector
  • Stock Status: In Stock
Product codes
Charge or Sync your iPhone, iPod, or iPad using a Micro USB cable. The USBUBLTADPW Lightning to Micro USB adapter for iPhone, iPod, iPad is colored to suit white mobile devices and provides a reliable solution for charging and syncing your Apple Lightning devices using a Micro USB cable.
This compact adapter is portable enough for carrying as a tablet or laptop accessory and it reduces the number of cables you need to carry around with you in order to charge all of your mobile devices.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable Lightning to Micro USB adapter is Apple MFi certified.
Product Description StarTech.com White Apple 8-pin Lightning Connector to Micro USB Adapter for iPhone / iPod / iPad - Apple Lightning to Micro USB Adapter (USBUBLTADPW) - Lightning adapter - Lightning / USB
Cable Lightning adapter - Lightning / USB
Colour White
Connector Lightning - male
Connector (Second End) Micro-USB Type B - female
Features Sync and charge
Designed For Apple iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus; iPod nano (7G); iPod touch (5G)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com White App...
£12.51
