StarTech.com White Micro USB to Apple 8-pin Lightning Connect...
StarTech.com White Micro USB to Apple 8-pin Lightning Connector Adapter for iPhone / iPod / iPad
£15.98
Colours:
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Length: 10.15cm
  • Stock Status: In Stock
Product codes
Charge or Sync your iPhone, iPod, or iPad using a Micro USB cable. The USBUBLTW White Lightning-to-Micro USB dongle adapter for iPhone, iPod, iPad enables you to sync and charge your Apple Lightning devices using a Micro USB cable.
Perfect for people on the go, the adapter allows you to use your existing Micro USB cable as a Lightning cable, saving you from having to carry multiple cables for your various mobile devices.
The dongle offers approximately 4-inches in cable length and provides a lightweight, portable design that fits nicely inside your laptop carrying case. Plus, the dongle lessens strain on the connector port and prevents damage to the cable, while also reducing the potential of blocking other nearby ports.
This durable adapter is Apple MFi certified.
Product Description StarTech.com White Micro USB to Apple 8-pin Lightning Connector Adapter for iPhone / iPod / iPad - Apple Lightning to Micro USB 2.0 Dongle (USBUBLTW) - Lightning adapter - Lightning / USB - 10.15 cm
Cable Lightning adapter - Lightning / USB
Technology Double shielded
American Wire Gauge (AWG) 24/28/32
Length 10.15 cm
Colour White
Connector Lightning - male
Connector (Second End) Micro-USB Type B - female
Designed For Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation); iPhone 5, 5c, 5s; iPod nano (7G); iPod touch (5G)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com White Mic...
£15.98
