StarTech.com WiGiG or USB-C Laptop Dock
£164.86
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Two versatile options to connect the dock to your host laptop: through WiGig (wireless) or USB-C (wired)
  • Supports dual monitors with 1920 x 1200p (60Hz) resolution on each display (DisplayPort and HDMI), or supports a single 4K monitor when connected through USB-C
  • Power and charge your laptop with support for USB Power Delivery (up to 60 watts) when connected through USB-C
Product codes
Create a full-size workstation using wireless docking (WiGig), or power and charge your laptop through USB Type-C (5Gbps). This versatile laptop docking station gives you the option to dock your laptop through either WiGig or USB-C . It's one of the first hybrid laptop docks that lets you connect to your laptop wirelessly, or through a wired USB-Type C port. With WiGig support, you have the flexibility to connect wirelessly, either now or in the future, and through USB-C you get a universal docking solution that's compatible with virtually all USB-C or Thunderbolt 3 equipped laptops.
This dynamic laptop dock is a must-have accessory if you have a laptop that supports WiGig (IEEE 802.11ad). With wireless docking, you can dock and undock your laptop without having to connect and disconnect a cable. That means you can save time and move more freely to and from your work area, with your laptop in hand.
Setting up is easy, and after you've paired the WiGig dock with your laptop for the first time, you can dock and undock by simply moving in and out of the docking station's wireless range (up to 4 ft.). This means that peripherals and devices connect and are ready to go even before you sit down, making it perfect for office and business workers who are constantly on the move.
Even if your current laptop doesn't support WiGig, this wireless docking station offers forward compatibility as WiGig enabled laptops become more readily available in the future.
The USB 3.0 docking station also gives you the option to connect through USB-C, if a WiGig connection isn't available. It capitalizes on the full potential of USB Type-C, which simultaneously transfers power, video, and data all over a single cable. USB-C is the future of universal connectivity, and many new laptops and tablets already feature USB Type-C ports.
The docking station supports USB Power Delivery (up to a maximum of 60 watts), which means that you can power and charge your laptop directly through its USB-C port. Because you can use just a single power adapter to power your dock and laptop, you can reduce clutter at your workstation. Plus, you don't need to carry or remember an extra power adapter when you're traveling to or from the office.
Note: USB Power Delivery is only supported when connected through USB-C. USB Power Delivery is not supported when connected through WiGig.
With DisplayPort and HDMI video output, this dock makes it easy to connect dual-monitors. Dual displays are supported in both WiGig and USB-C modes. With multiple monitors, you can work more efficiently by multitasking faster, and avoid the hassle of continually repositioning several open windows or programs.
This full-featured universal docking station offers the ports you need to create a full-sized workstation, including four USB 3.0 ports (2x USB 3.0, and 2x USB 2.0 ports including a fast charge-and-sync port) plus Gigabit Ethernet, and headset connections.
Unlike some proprietary docking stations that are designed to only work with specific laptop models when connected through USB-C, this universal docking station works with multiple brands. All you need is a laptop with Windows 10 and a USB-C port that supports DP alt mode and USB Power Delivery, and you can be up and running quickly. With universal support, you can use this USB-C dock with different laptops now, or in the future.
Product Description StarTech.com Dual Monitor USB C Dock - 60W Power Delivery - 4K - wireless docking station - HDMI, DP
Product Type Wireless docking station
Docking Interface USB-C
Video Interfaces HDMI, DP
Dimensions (WxDxH) 5.2 cm x 12.1 cm x 20.3 cm
Weight 700 g
Colour Black & silver
Networking Gigabit Ethernet, IEEE 802.11ad (WiGig)
Power Power adapter AC 120/230 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com WiGiG or...
£164.86
