StarTech.com Wireless Presentation Remote
£30.70
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Engage your audience, move freely around the room, with a wireless range of up to 90 ft. (27 m)
  • Easily control your presentation with intuitive push-button operation and no additional software or drivers required
  • Draw your audience's attention to specific on-screen content, using the built-in laser pointer
  • Stock Status: In Stock
Product codes
This presentation remote control helps you deliver seamless presentations by combining intuitive navigation and a laser pointer in a single compact unit.
Being confined to your computer isn't the most effective way to deliver a presentation, especially when you're trying to engage your audience.
With a wireless range of 90 ft. (27 m), this presentation clicker puts you in control of what's on your screen, giving you the freedom to move around the room while controlling your presentation as if you were at your computer. This is ideal for presenting in large lecture halls or conference centers.
With a built-in laser pointer, the presentation remote lets you guide your audience's attention to critical information in your content. It's perfect for PowerPoint presentations, websites or any other documents you want to share with your audience.
The remote control features a sleek, ergonomic design and includes the required batteries along with a protective carrying case, for total portability. You can store the wireless receiver inside the presentation remote when you're not using it. The USB receiver is supported by generic HID drivers ensuring it will work with virtually any Mac or Windows computer.
Product Description StarTech.com Wireless Presentation Remote w/ Red Laser Pointer - 90' presentation remote control
Device Type Presentation remote control
Dimensions (WxDxH) 3.1 cm x 13.4 cm x 6.6 cm
Weight 120 g
Connectivity Technology Radio
Max Operating Distance 27 m
Battery 2 AAA type
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Wireless...
£30.70
