StarTech.com Wireless Presentation Remote w/ Green Laser Poin...
StarTech.com Wireless Presentation Remote w/ Green Laser Pointer - 90’
£43.00
35 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Draw your audience's attention to specific on-screen content, using the built-in laser pointer
  • The vibrant green colored laser produces a higher visibility on projectors and LCD/LED HD screens than traditional red colored pointers
  • Engage your audience, move around the room, with a wireless range of up to 90 ft. (27 m)
  • Stock Status: In Stock
Product codes
This wireless presentation remote lets you engage your audience, draw their attention and control your presentation. It's ideal for presenting in large lecture halls, or conference centers.
With a built-in green laser pointer, the presentation remote lets you guide your audience's attention to critical information in your content. It's perfect for PowerPoint presentations, websites or any other documents you want to share.
The green laser works on surfaces where red lasers won't display. It appears nicely on bright projector or LCD/LED HD screens.
The presentation clicker features a wireless range of 90 ft. (27 m). It gives you control of what's on the screen throughout the room, and the freedom to move around and present as if you were at your computer.
You can: Navigate through your slides; Black out the screen to focus your audience's attention solely on you or something else in the room; Control the volume of a video.
The remote features a sleek, ergonomic design and includes the required batteries along with a protective carrying case, for total portability. You can store the wireless receiver inside the presentation remote when you're not using it and the remote will automatically power off.
The USB receiver works with virtually any Mac or Windows computer. Simply plug the receiver into your laptop and you're ready to present.
Product Description StarTech.com Wireless Presentation Remote w/ Green Laser Pointer - 90' presentation remote control - black
Device Type Presentation remote control
Enclosure Colour Black
Dimensions (WxDxH) 3.1 cm x 13.4 cm x 2.5 cm
Weight 120 g
Connectivity Technology Radio
Supported Devices Projector, LCD display
Wireless Technology 2.4 GHz
Max Operating Distance 27 m
Battery 2 AAA type
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Wireless...
£43.00
