This wireless presentation remote lets you engage your audience, draw their attention and control your presentation. It's ideal for presenting in large lecture halls, or conference centers.
With a built-in green laser pointer, the presentation remote lets you guide your audience's attention to critical information in your content. It's perfect for PowerPoint presentations, websites or any other documents you want to share.
The green laser works on surfaces where red lasers won't display. It appears nicely on bright projector or LCD/LED HD screens.
The presentation clicker features a wireless range of 90 ft. (27 m). It gives you control of what's on the screen throughout the room, and the freedom to move around and present as if you were at your computer.
You can: Navigate through your slides; Black out the screen to focus your audience's attention solely on you or something else in the room; Control the volume of a video.
The remote features a sleek, ergonomic design and includes the required batteries along with a protective carrying case, for total portability. You can store the wireless receiver inside the presentation remote when you're not using it and the remote will automatically power off.
The USB receiver works with virtually any Mac or Windows computer. Simply plug the receiver into your laptop and you're ready to present.
Product Description | StarTech.com Wireless Presentation Remote w/ Green Laser Pointer - 90' presentation remote control - black | Device Type | Presentation remote control | Enclosure Colour | Black | Dimensions (WxDxH) | 3.1 cm x 13.4 cm x 2.5 cm | Weight | 120 g | Connectivity Technology | Radio | Supported Devices | Projector, LCD display | Wireless Technology | 2.4 GHz | Max Operating Distance | 27 m | Battery | 2 AAA type | Manufacturer Warranty | 2-year warranty |
General | |
Width | 3.1 cm |
Depth | 13.4 cm |
Height | 2.5 cm |
Weight | 120 g |
Features | Built-in laser pointer, LED indicator |
Miscellaneous | |
Included Accessories | Carrying case, 2 AAA batteries, USB wireless receiver |
Compliant Standards | FCC, RoHS, Laser Class 2 |
Dimensions & Weight (Shipping) | |
Shipping Width | 9.6 cm |
Shipping Depth | 19 cm |
Shipping Height | 4.5 mm |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 30 - 80% |
Power | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
