Easy to install and with the convenience of wireless connection, you can now easily protect your property with the Swann outdoor security camera. Just use the long power extension cable to plug into power, while video transmission is wireless. It connects directly to the Wi-Fi router, no need for a DVR or base station. See in the dark for up to 100 feet (30 meters) for 24/7 protection, while audio capture adds another layer of evidence to your footage.
Product Description | Swann SWWHD-OUTCAM - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor, indoor - weatherproof | Audio | Yes: built-in microphone | Dimensions (WxDxH) | 18.6 cm x 8 cm x 6 cm | Weight | 452 g | Connectivity Technology | Wired, wireless | Camera | Colour - Day&Night | Max Resolution | 1920 x 1080 | Video Modes | 1080p | Optical Sensor Type | 2 MP | Interfaces | Wi-Fi, LAN | Cables Included | 1 - power extension cable - external - 18 m | Features | Infrared cut filter, True Detect (PIR Thermal Sensing) | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -20 °C - 45 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in microphone |
Width | 18.6 cm |
Depth | 8 cm |
Height | 6 cm |
Weight | 452 g |
Localisation | United Kingdom |
Camera | |
Type | Colour - Day&Night - fixed - outdoor, indoor - weatherproof |
Max Digital Video Resolution | 1920 x 1080 |
Infrared LEDs | Yes |
Infrared Distance | 30 m |
Image Sensor | |
Type | 2 MP |
Lens Construction | |
Horizontal Field of View (degree) | 110 |
Interfaces | |
Network Interface | Wi-Fi, LAN |
Miscellaneous | |
Included Accessories | Antenna, theft deterrent sticker, screw kit |
Cables Included | 1 x power extension cable - external - 18 m |
Compliant Standards | IP66 |
Power | |
Power Device | Power adapter - external |
Internet of Things (IoT) | |
Intelligent Assistant Compatible | Alexa |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
