We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | Synology - DDR4 - module - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered | Product Type | Memory module | Capacity | 16 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin | Upgrade Type | System specific | Data Integrity Check | ECC | Speed | 2400 MHz (PC4-19200) | Features | Unbuffered | Voltage | 1.2 V | OEM Manufacturer Equivalent Part Number | Synology D4EC-2400-16G | Designed For | RackStation RS1619xs+, RS2418+, RS2418RP+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS4017XS+ |
General | |
Capacity | 16 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin |
Voltage | 1.2 V |
Compatibility Information | |
Designed For | Synology RackStation RS1619xs+, RS2418+, RS2418RP+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS4017XS+ |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
