We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | Synology HAS5300 - hard drive - 8 TB - SAS 12Gb/s | Type | Hard drive - internal | Capacity | 8 TB | Form Factor | 3.5" | Interface | SAS 12Gb/s | Data Transfer Rate | 1.2 GBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | NAS compatible, Enterprise, workload up to 550 TB per year | Dimensions (WxDxH) | 101.85 mm x 147 mm x 26.1 mm | Weight | 770 g | Manufacturer Warranty | 5-year warranty | Designed For | Synology SA3200D, SA3400, SA3600; High Density HD6500; RackStation RS18016xs+, RS18017XS+; Unified Controller UC3200 |
General | |
Device Type | Hard drive - internal |
Capacity | 8 TB |
Bytes per Sector | 512 |
Width | 101.85 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 770 g |
Performance | |
Drive Transfer Rate | 1.2 GBps (external) |
Internal Data Rate | 230 MBps |
Reliability | |
MTBF | 2,500,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SAS 12 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 6.62 Watt (idle) , 9.87 Watt (random read/write) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Compatibility Information | |
Designed For | Synology SA3200D, SA3400, SA3600 , Synology High Density HD6500 , Synology RackStation RS18016xs+, RS18017XS+ , Synology Unified Controller UC3200 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
