An ideal first NAS for everyone
DS119j is an ideal entry-level network-attached storage solution for personal users. Fast yet power-saving, DS119j brings an intuitive file management experience with great data transmission speed and extremely low power consumption.
Easy file access with QuickConnect
Access files on your Synology NAS over the Internet without the hassle of setting up port forwarding rules, DDNS, or other complicated network settings. QuickConnect allows you to connect via a secure, customizable address, so that you can instantly access media and work files on any Internet-connected device with no additional charge.
Synchronize files across your devices
Cloud Station Suite provides real-time data synchronization across all your devices and other Synology NAS. "Intelliversioning" keeps the most important file versions to better utilize storage space.
Seamless integration with your mobile devices
Synology mobile applications are designed to allow quick and secure access to your data wherever you are.
Surveillance Station
Complete surveillance solution for recording, monitoring, and management.
Desktop Backup
Simplified backup solution for your Mac, PC, and mobile devices.
File Server/Management
Powerful built-in file management and sharing services.
DSM UI
Award-winning operating system with an intuitive user interface and powerful capabilities.
Security
Comprehensive built-in security tools are constantly updated to tackle evolving threats and protect your devices.
Multimedia
Complete multimedia solution for management, streaming, and playback.
Product Description | Synology Disk Station DS119j - personal cloud storage device - 3 TB | Device Type | Personal cloud storage device | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 3 TB | Installed Devices / Modules Qty | 1 (installed) / 1 (max) | Dimensions (WxDxH) | 7.1 cm x 22.4 cm x 16.6 cm | Processor | 1 x Marvell ARMADA 3720 800 MHz (Dual-Core) | Storage Controller | SATA SATA 6Gb/s | Hard Drive | 1 x 3 TB | Networking | 10Mb LAN, 100Mb LAN, GigE | IP Cameras Supported | 5 | RAM | 256 MB | Power | AC 120/230 V (50/60 Hz) | System Requirements | Microsoft Windows 7, Windows 10, Apple MacOS X 10.11 or later | Manufacturer Warranty | 2-year warranty |
General | |
Width | 7.1 cm |
Depth | 22.4 cm |
Height | 16.6 cm |
Processor / Memory | |
Processors Installed | 1 x Marvell ARMADA 3720 800 MHz |
Number of Cores | Dual-Core |
Max Supported Qty | 1 |
RAM | 256 MB DDR3 |
Storage Controller | |
Type | SATA |
Interface Type | SATA 6Gb/s |
Hard Drive | |
Type | HDD |
Capacity | 1 x 3 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | TCP/IP, PPTP, L2TP, PPPoE, iSCSI, SMTP, FTP, POP3, IMAP |
Remote Management Protocol | SNMP, Telnet, HTTP, HTTPS, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Firewall protection, VPN support, LDAP support, Access Control List (ACL) support, RADIUS support, FTP server, DNS server, VPN Server, file station |
Encryption Algorithm | SSL, TLS |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 1 (total) / 0 (free) x internal - 2.5" / 3.5" |
Interfaces | 2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 1 x network cable |
Features | Security lock slot (cable lock sold separately), built-in cooling fan |
Security Slot Type | Kensington security slot |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software / System Requirements | |
OS Required | Microsoft Windows 7, Windows 10, Apple MacOS X 10.11 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
