Synology DS1817+ (2GB)/24TB-RED 8 Bay NAS
Key features
  • Centralized storage solution with outstanding performance
  • Supercharge your storage with speedy performance
  • Next-generation file system for effective data protection
  • Ultimate file management and sharing
Product codes
  • Quad-core 8-bay NAS with AES-NI support, with over 1,179 MB/s reading and 542 MB/s writing performance
  • PCIe slot for optional 10GbE add-on card. Four 1GbE (RJ-45) ports with failover and Link Aggregation support.
  • Optional M2D17 adapter card for dual M.2 SATA SSDs for cache
  • Two memory configurations: 2GB & 8GB with easily upgradable dual-channel design, up to 16GB
  • Advanced Btrfs file system offering 65,000 system-wide snapshots and 1,024 snapshots per shared folder
  • Scale up to 18 drives with two DX517 expansion units
Synology DiskStation DS1817+ features a quad-core processor with AES-NI hardware encryption engine, providing outstanding performance even with encryption. Supercharge your storage with the optional M.2 SSD adapter card for dual SSD cache drives. DS1817+ is the ideal storage solution for centralizing data backups, protecting critical assets, and sharing files across different platforms. Synology DS1817+ is backed with Synology’s 3-year limited warranty.
Product Description Synology Disk Station DS1817+ - NAS server - 24 TB
Device Type NAS server
Host Connectivity Gigabit Ethernet
Total Storage Capacity 24 TB
Max Supported Capacity 80 TB
Installed Devices / Modules Qty 8 (installed) / 8 (max)
Dimensions (WxDxH) 34.3 cm x 24.3 cm x 16.6 cm
Processor 1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive 8 x 3 TB SATA 6Gb/s
Networking 10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported 40
RAM 2 GB
Power AC 120/230 V (50/60 Hz)
Storage Operating System Synology DiskStation Manager
System Requirements Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
Manufacturer Warranty 3 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Synology DS1817+ (2GB)...
