Synology DS1817+ (2GB)/32TB-IW PRO NAS
Key features
  • Centralized storage solution with outstanding performance
  • Supercharge your storage with speedy performance
  • Next-generation file system for effective data protection
  • Ultimate file management and sharing
Product codes
Synology DiskStation DS1817+ is a 8-bay NAS powered by a quad-core CPU with AES-NI hardware encryption engine. Coming with quad 1GbE LAN ports, it can be installed with a 10GbE network interface card (NIC) or a dual M. 2 SSD adapter card, thereby enhancing network speeds or boosting performance with SSD cache.
Equipped with dual-channel memory and a PCIe slot, DS1817+ supports installing the dual M. 2 SSD adapter card, M2D17, or the 10GbE NIC, for high-IOPS system cache and ultra-fast data transmission respectively.
Product Description Synology Disk Station DS1817+ - NAS server - 32 TB
Device Type NAS server
Host Connectivity Gigabit Ethernet
Total Storage Capacity 32 TB
Max Supported Capacity 80 TB
Installed Devices / Modules Qty 8 (installed) / 8 (max)
Dimensions (WxDxH) 34.3 cm x 24.3 cm x 16.6 cm
Processor 1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive 8 x 4 TB SATA 6Gb/s
Networking 10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported 40
RAM 2 GB
Power AC 120/230 V (50/60 Hz)
Storage Operating System Synology DiskStation Manager
System Requirements Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
Manufacturer Warranty 3 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Synology DS1817+ (2GB)...
