General |
Device Type |
NAS server |
Host Connectivity |
Gigabit Ethernet |
Total Storage Capacity |
4 TB |
Installed Devices / Modules Qty |
2 (installed) / 2 (max) |
Width |
10 cm |
Depth |
22.55 cm |
Height |
16.5 cm |
Weight |
870 g |
Processor / Memory |
Processors Installed |
1 x Marvell ARMADA 385 1.3 GHz |
Number of Cores |
Dual-Core |
Max Supported Qty |
1 |
RAM |
512 MB DDR3 |
Storage Controller |
Type |
RAID |
Interface Type |
SATA 6Gb/s |
RAID Level |
RAID 0, RAID 1, JBOD |
Hard Drive |
Type |
HDD |
Capacity |
2 x 2 TB |
Networking |
Data Link Protocol |
10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol |
PPTP, L2TP, IPSec, iSCSI, FTP, SMB, NFS, SFTP |
Remote Management Protocol |
SNMP, Telnet, HTTP, HTTPS, SSH |
Network Services Compatibility |
Microsoft Active Directory (AD), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features |
Firewall protection, Access Control List (ACL) support, iTunes server, FTP server, reset button, PXE support, DNS server, VPN Server |
Encryption Algorithm |
SSL, TLS |
Compliant Standards |
DLNA CERTIFIED |
Security DVR |
IP Cameras Supported |
14 |
Compression Format |
H.264 |
Expansion / Connectivity |
Expansion Bays |
2 (total) / 0 (free) x internal - 2.5" / 3.5" |
Interfaces |
2 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 |
Miscellaneous |
Cables Included |
1 x network cable |
Features |
Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan, hardware encryption, Hybrid RAID, VPN support |
Security Slot Type |
Kensington security slot |
RoHS |
Power |
Power Device |
External power adapter |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Manufacturer Warranty |
Service & Support |
Limited warranty - 2 years |
Environmental Parameters |
Min Operating Temperature |
5 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
5 - 95% |
