Synology DS2415+ 72TB (12 x 6TB WD RED PRO) 12 Bay Desktop NAS
Key features
  • High-speed data transfer and hardware encryption engine
  • Dual LAN ports for failover and Link Aggregation support
  • Easy installation, hassle-free maintenance
  • USB 3.0 and eSATA ensure speedy transfers to external storage
  • DiskStation Manager
  • Seamless storage solution for virtualization environments
  • Fit into business environments easily
  • Optimize storage management
  • The most compatible sharing
  • Effective backup solution
  • All-in-One server
  • Ensuring business continuity
  • Increase business productivity with cloud solutions
  • Secure your data
  • Eco-friendly NAS server
Product codes
Featuring a quad-core processor, hardware encryption engine, and flawless software integration, DS2415+ is a powerful, expandable 12-bay NAS server that delivers outstanding speed and accelerated data encryption. Easily scalable, the DS2415+ can be equipped with up to 6GB of DDR3 RAM and host up to 144TB of raw capacity with a Synology DX1215 expansion unit.
Contains the WD Red Pro HDD's NAS optimised for 19" rack mount solutions with multi Axis shock sensors, vibration protection & dual actuators. With 5 years warranty
Product Description Synology Disk Station DS2415+ - NAS server - 72 TB
Device Type NAS server
Host Connectivity Gigabit Ethernet
Total Storage Capacity 72 TB
Max Supported Capacity 144 TB
Installed Devices / Modules Qty 12 (installed) / 12 (max)
Dimensions (WxDxH) 30 cm x 34 cm x 27 cm
Processor 1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
Hard Drive 12 x 6 TB SATA 6Gb/s
Networking 10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported 40
RAM 2 GB
Power AC 120/230 V (50/60 Hz)
Storage Operating System Synology DiskStation Manager
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Synology DS2415+ 72TB...
