Synology DX513 10TB Desktop Expansion NAS
£822.80
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Online volume expansion
  • Dedicated local backup solution
  • Reliable plug-and-use design
  • Hot-swappable HDD design
  • Auto power on/off with DiskStation models
  • Capacity: 10TB
  • Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Type: 5-Bay
  • Stock Status: In Stock
Product codes
Synology DX513 delivers an effortless solution for volume expansion and data backup for selected Synology DiskStation models. The DX513 seamlessly scales up the storage capacity of the DiskStation by additional 5 hard drives on-the-fly when connected directly to an expansion cable.
Product Description Synology DX513 - storage enclosure
Device Type Storage enclosure
Installed Devices / Modules Qty 5 (installed) / 5 (max)
Hard Drive 5 x 2 TB HDD - hot-swap
Power AC 120/230 V - 50 - 60 Hz
Dimensions (WxDxH) 24.8 cm x 23.3 cm x 15.7 cm
Weight 3.91 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Synology DX513 10TB De...
£822.80
