Synology DX513 40TB (5 x 8TB WD Red) 5 Bay Desktop Expansion...
Synology DX513 40TB (5 x 8TB WD Red) 5 Bay Desktop Expansion Unit
£1,704.73
Delivery:
Standard: 1-3 working days
Key features
  • Online volume expansion
  • Dedicated local backup solution
  • Reliable plug-and-use design
  • Hot-swappable HDD design
  • Auto power on/off with DiskStation models
Product codes
Synology DX513 delivers an effortless solution for volume expansion and data backup for selected Synology DiskStation models. The DX513 seamlessly scales up the storage capacity of the DiskStation by additional 5 hard drives on-the-fly when connected directly to an expansion cable.
Synology DX513 - storage enclosure
Storage enclosure
5 (installed) / 5 (max)
Supported Drives
SATA-600
Hard Drive
5 x 8 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
24.8 cm x 23.3 cm x 15.7 cm
3.91 kg
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Synology DX513 40TB (5...
£1,704.73
