Synology DX513 5-Bay NAS Expansion Unit
£378.38
Delivery:
Key features
  • Online volume expansion
  • Dedicated local backup solution
  • Reliable plug-and-use design
  • Hot-swappable HDD design
  • Auto power on/off with DiskStation models
Product codes
Documents
DiskStation DX513
Synology® DX513 delivers an effortless solution for volume expansion and data backup for selected Synology DiskStation models. The DX513 seamlessly scales up the storage capacity of the DiskStation by additional 5 hard drives on-the-fly when connected directly to an expansion cable.
Volume Expansion & Backup
When running out of hard drive capacity on the Synology DiskStation, Synology DX513 provides an easy way to immediately scale capacity by additional 5 hard drives. The RAID volume on the Synology DiskStation can be expanded directly without having to reformat the existing hard drives, ensuring the Synology DiskStation continues its service during the capacity expansion.
Synology DX513 can be used as a dedicated local backup solution for the Synology DiskStation. When created as a separate volume, the Synology DX513 provides a great backup solution to its local hard disks in case of system failure.
Reliable Plug-n-use Design
The Synology DX513 is connected to the Synology DiskStation using an expansion cable with custom-designed connectors on both ends, ensuring a reliable connection and maximum throughput. The 3.0 Gb/sec connection speed allows the hard drives in the connected Synology DX513 to operate as the internal ones of Synology DiskStation.
Green & Easy to Manage
The HDD hibernation and system hibernation can be manually configured to take effect automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of the hard disk. The DX513 will also smartly power on/off with the attached DiskStation, so no user intervention is needed to keep this system running smartly and efficiently.
Technical Specifications
  • Internal HDD/SSD 3.5" or 2.5" SATA(II) X 5 (hard drives not included)
  • Expansion Port X 1
  • Hot Swappable HDD Yes
  • Volume Type Synology Hybrid RAID, Basic, JBOD, RAID 0, RAID 1, RAID 10, RAID 5, RAID 5+Spare, RAID 6
  • Size (HxWxD) 157mm X 248mm X 233mm
  • Weight 3.91KG
  • System Fan 80x80mm X 2
  • Noise Level1 30dB(A)
  • Power Recovery Sync with the connected DiskStation (Default Mode)
  • AC Input Power Voltage 100V to 240V
  • Power Frequency 50Hz to 60Hz, Single Phase
  • Operating Temperature 5°C to 35°C (40°F to 95°F)
  • Storage Temperature -10°C to 70°C (15°F to 155°F)
  • Relative Humidity 5% to 95%RH
  • Maximum Operating Altitude 10,000feet
  • Power Consumption2 45.1W (Access), 16.5W (HDD Hibernation)
  • Supported Models3 DS710+, DS712+, DS1010+, DS1511+, DS1512+, DS1812+
  • DS112, DS112+, DS212+, DS213+, DS412+, DS413 (use as independent volume)
Synology DX513 - storage enclosure
Storage enclosure
Max Supported Capacity
60 TB
0 (installed) / 5 (max)
Hard Drive
0 HDD - hot-swap
AC 120/230 V - 50 - 60 Hz
24.8 cm x 23.3 cm x 15.7 cm
3.91 kg
3 years warranty
Disk Station DS1010+, DS1511+, DS1512+, DS1812+, DS710+, DS712+
Resources
The following resources are available for the Synology DX513 5-Bay NAS Expansion Unit
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Synology DX513 5-Bay N...
£378.38
