Synology's first mesh router, MR2200ac, comes with Qualcomm IPQ4019 quad-core CPU and tri-band Wi-Fi, allowing users to expand Wi-Fi coverage through flexible deployment. All Wi-Fi connections and devices can be managed via one platform - SRM. Additionally, settings and remote management can be operated through both a web interface and a dedicated mobile app - DS router.
Product Description | Synology MR2200AC - wireless router - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Capacity | Connection / user qty: 90 , IPv6 routes (static): 100 , IPv4 routes (static): 100 | Network / Transport Protocol | PPTP, L2TP, IPSec, PPPoE, DDNS | Routing Protocol | Static IPv4 routing, static IPv6 routing | Remote Management Protocol | SNMP, SSH | Features | NAT support, wake on LAN (WOL), IGMP snooping, print server, MAC address filtering, IPv6 support, DFS support, VPN passthrough, parental control, Access Point operational mode, firmware upgradable, Quality of Service (QoS), RADIUS support, DHCP server, port forwarding, UPnP Media Server, reset button, DNS server, DLNA Media Server, Apple Time Machine compatible, port triggering, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, DHCP client, e-mail notification, VPN Server, SNMP support, MU-MIMO technology, Wi-Fi Protected Setup (WPS v2), beamforming technology, seamless roaming, Denial of Service (DoS) protection, DMZ support, cloud station server, traffic monitoring | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 19.9 cm x 6.5 cm x 15.4 cm | Weight | 450 g | Manufacturer Warranty | 2-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WEP, WPA3 |
Authentication Method | RADIUS |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, BSMI, JATE, IC, FCC, RoHS, TELEC, KC, VCCI Class B, NCC, iDA, RCM |
Processor | 1 x 717 MHz |
RAM | 256 MB DDR3 SDRAM |
Expansion / Connectivity | |
Interfaces | LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Aerial | |
Aerial | Internal |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 12.95 Watt |
Miscellaneous | |
Cables Included | 1 x network cable |
Dimensions & Weight | |
Width | 19.9 cm |
Depth | 6.5 cm |
Height | 15.4 cm |
Weight | 450 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
