Synology RS18016xs+/120TB (12x10TB Seagate IronWolf Pro) 2U 1...
Synology RS18016xs+/120TB (12x10TB Seagate IronWolf Pro) 2U 12 bay
Key features
  • Superior performance
  • SSD cache technology
  • Dual 10GbE NIC and SAS & SATA III 6Gb/s support
  • Reliable redundancy mechanisms
  • Hardware encryption engine for enhanced file transfer speeds
  • Protection by LUN backup, snapshot, and clone
Product codes
RS18016xs+ delivers superior performance at over 3,900 MB/s throughput and 348,000 IOPS under RAID 5 configuration. RS18016xs+ is equipped with 8GB ECC RAM, expandable to 32 GB if needed, so enterprises can guarantee data accuracy, as well as superior performance for the mission-critical tasks of the business.
RS18016xs+ supports a combination of hard drives and read/write-optimized SSD cache, boosting throughput efficiently while minimizing cost per gigabyte. With full SSD cache reading and writing support, RS18016xs+ offers a significant reduction in I/O latency without crippling your budget. With only a small upfront investment, businesses can benefit from significant enhancement in server performance.
In addition to the default 4 Gigabit ports, RS18016xs+ includes two PCIe 3.0 x8 slots, allowing installation of two dual-port 10GbE network interface cards for maximized bandwidth, bringing you the superior performance that data-intensive applications demand of your storage system. With native SAS & SATA III 6Gb/s interface support, RS18016xs+ ensures the optimum data process under heavy system loading.
Synology RackStation RS18016xs+ - NAS server - 120 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
120 TB
12 (installed) / 12 (max)
43 cm x 69.2 cm x 8.8 cm
14.5 kg
1 x Intel Xeon E3-1230V2 3.3 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s / SAS - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 10 TB SATA 6Gb/s - Native Command Queuing (NCQ), Halogen Free, PowerChoice, Hot-Plug Support, advanced format 512e, 24x7 availability
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
90
RAM
8 GB
Power Redundancy
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Synology RS18016xs+/12...
