Synology RS18017xs+ 48TB (12x4TB WD RED PRO) 12 Bay Rackmount...
Synology RS18017xs+ 48TB (12x4TB WD RED PRO) 12 Bay Rackmount NAS
£6,937.60
Delivery:
Key features
  • Synology iSCSI storage fully supports most virtualization solutions to enhance work efficiency with easy management interface
  • Seamlessly integrate the Synology NAS to your business environments with comprehensive productivity tools
Product codes
RS18017xs+ is built for flexible storage management with ultra-high performance at over 568,000 sequential read IOPS and 4,800 MB/s sequential read throughput. DDR4 ECC RDIMM and 10GbE connectivity guarantees data accuracy and performance for mission-critical environment.
Product Description Synology RackStation RS18017XS+ - NAS server - 48 TB
Device Type NAS server
Host Connectivity Gigabit Ethernet
Enclosure Type Rack-mountable - 2U
Total Storage Capacity 48 TB
Installed Devices / Modules Qty 12 (installed) / 12 (max)
Dimensions (WxDxH) 48.2 cm x 72.4 cm x 8.8 cm
Weight 14.5 kg
Processor 1 x Intel Xeon D-1531 2.2 GHz (6-core)
Storage Controller RAID SATA 6Gb/s / SAS - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive 12 x 4 TB
Networking 10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported 90
RAM 16 GB
Power AC 120/230 V (50/60 Hz)
Power Redundancy Yes
Storage Operating System Synology DiskStation Manager
System Requirements Microsoft Windows XP or later, Apple MacOS X 10.10 or later
Manufacturer Warranty 5 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Synology RS18017xs+ 48...
£6,937.60
