Synology RS818+ 40TB (4 x 10TB IWPRO) 4 Bay Rack Mountable
£2,408.43
Delivery:
Standard: 1-3 working days
Key features
  • Flexible Shared Folder and User Quota System provides comprehensive quota control on all user accounts and shared folders
  • Snapshot Replication provides schedulable and storage capacity-saving data protection with 1,024 shared folder backups and 65,000 system-wide snapshots
  • File or folder level data restoration makes data recovery fast and flexible
  • Automatic file self-healing detects and recovers corrupted files without user intervention
Product codes
Powerful and scalable storage solution
Synology RackStation RS818+/RS818RP+ comes with a quad-core processor with the AES-NI hardware encryption engine, quad 1GbE LAN ports, and optional 10GbE NIC support. It provides both high performance and a scalable storage solution for sharing files across different platforms, centralizing data backups, and protecting critical assets.
Built for high service reliability
RS818+ comes with four 1Gbe LAB ports to supporrt Link Aggretion and failover. Synology High Availability support provides a reliable active/passive server cluster, keeping data and services online. Furthemore, RS818RP+ is equipped with redundant power supplies to deliver increased service continuty.
Real-time collaboration on your private cloud
Office is a collaboration package combining the convenience and usability of public clouds with the data privacy and security guaranteed by private clouds. It allows you to work seamlessly together on documents and spreadsheets in a protected environment.
Fully certified storage virtualization solutions
Synology iSCSI storage fully supports most virtualization solutions to enhance work efficiency with easy management interface. VMware vSphere 6 and VAAI integration helps offload storage operations and optimizes computation efficiency. Windows Offloaded Data Transfer (ODX) speeds up data transfer and migration rate. OpenStack Cinder support turns your Synology NAS into a block-based storage component.
40TB (4 x 10TB) WD IWPRO Hard Drive included!
Product Description Synology RackStation RS818+ - NAS server - 40 TB
Device Type NAS server
Host Connectivity Gigabit Ethernet
Enclosure Type Rack-mountable - 1U
Total Storage Capacity 40 TB
Max Supported Capacity 48 TB
Installed Devices / Modules Qty 4 (installed) / 4 (max)
Dimensions (WxDxH) 43.05 cm x 45.76 cm x 4.4 cm
Processor 1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
Hard Drive 4 x 10 TB SATA 6Gb/s
Networking 10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported 40
RAM 2 GB
Power AC 120/230 V (50/60 Hz)
Storage Operating System Synology DiskStation Manager
System Requirements Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Synology RS818+ 40TB (...
£2,408.43
