Blazing-fast Wi-Fi with up to 2.53 Gbps combined wireless bandwidth to supercharge your network. RT2600ac is a powerful wireless router for homes and small offices seeking to work and play smarter, featuring comprehensive VPN solutions, enhanced security, and flexible media and file sharing capabilities.
Product Description | Synology RT2600ac - wireless router - 802.11a/b/g/n/ac - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 2 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Data Transfer Rate | 2.53 Gbps | Capacity | Connection / user qty: 120 | Network / Transport Protocol | PPTP, L2TP, IPSec, PPPoE, FTP, DDNS | Routing Protocol | IGMP, static IP routing | Remote Management Protocol | SNMP, SSH | Features | Firewall protection, DMZ port, DHCP support, NAT support, VPN support, wake on LAN (WOL), IGMP snooping, DoS attack prevention, dynamic DNS server, manageable, print server, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, parental control, Access Point operational mode, firmware upgradable, download client, Quality of Service (QoS), RADIUS support, SSH support, DHCP server, SMS alert, BitTorrent Client, Wireless Client Mode, DNS server, DLNA Media Server, port triggering, Stateful Packet Inspection Firewall (SPIF), eMule client, 3G/4G USB Dongle Support, Traffic Control, DHCP client, e-mail notification, 4T4R MIMO technology, VPN Server, SNMP support, Wi-Fi Protected Setup (WPS v2), beamforming technology | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac | Power | AC 100/230 V (50/60 Hz) | Dimensions (WxDxH) | 28 cm x 16.9 cm x 7.7 cm | Weight | 700 g | Manufacturer Warranty | 2-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WEP |
Authentication Method | RADIUS |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac, FCC Class B certified, RoHS, BSMI Class B, NCC, iDA, RCM |
Processor | 1 x 1.7 GHz |
RAM | 512 MB DDR3 SDRAM |
Status Indicators | Power, status, WAN, LAN |
Expansion / Connectivity | |
Interfaces | LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A |
Expansion Slots | 1 SDXC |
Aerial | |
Aerial | External detachable |
Antenna Qty | 4 |
Directivity | Omni-directional |
Power | |
Power Device | External power adapter |
Voltage Required | AC 100/230 V (50/60 Hz) |
Power Consumption Operational | 10.8 Watt |
Miscellaneous | |
Cables Included | 1 x network cable |
Dimensions & Weight | |
Width | 28 cm |
Depth | 16.9 cm |
Height | 7.7 cm |
Weight | 700 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
