Synology RX418 16TB(4 x 4TB IWPRO) 4 Bay Rack Mountable
£1,240.11
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Storage capacity expansion
  • Reliable plug-and-play design
  • Green and easy to manage
Product codes
When the storage capacity on Synology 1U RackStation reaches its limit, Synology expansion unit RX418 provides easy capacity expansion by adding 4 3.5"/2.5" SATA drives to the system. Synology RX418 can also be used as a dedicated local backup destination of Synology 1U RackStation for comprehensive data protection.
Simply connect Synology RX418 to corresponding Synology RackStation and it is ready to use. Drives in the connected Synology RX418 operate as though they were internal to the connected Synology NAS and can be managed directly by Synology DiskStation Manager (DSM), with no additional software installation required.
Award-winning Synology DSM provides an intuitive user interface for easy system management. Drive hibernation can be configured in DSM to take effect automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of the installed drives.
16TB (4 x 4TB) IWPRO Hard Drives included
Synology RX418 Expansion Unit - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 1U
4 (installed) / 4 (max)
Supported Drives
SATA-600
Built-in Devices
Led panel
Hard Drive
4 x 4 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
43.05 cm x 29 cm x 4.4 cm
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Synology RX418 16TB(4...
£1,240.11
