We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Synology SNV3500 NVMe SSD is designed to handle tough caching workloads in a 24/7 multi-user environment. Its durable I/O performance boosts system responsiveness and speeds up handling of frequent access data, providing a streamlined storage experience while minimizing service disruptions to your Synology NAS.
Designed for use in Synology systems only, warranty claims will be rejected when used in non-Synology devices
Product Description | Synology SNV3500-400G - SSD - PCIe 3.0 x4 (NVMe) | Type | Solid state drive - internal | Form Factor | M.2 22110 | Interface | PCIe 3.0 x4 (NVMe) | Features | End-to-end data protection, NVM Express (NVMe) | Dimensions (WxDxH) | 22 mm x 110 mm x 4.5 mm | Manufacturer Warranty | 5-year warranty | Designed For | Synology SA3400, SA3600; Disk Station DS1618+, DS1819+, DS2419+, DS3018xs; RackStation RS2818RP+, RS820+, RS820RP+ |
General | |
Device Type | Solid state drive - internal |
Width | 22 mm |
Depth | 110 mm |
Height | 4.5 mm |
Performance | |
Drive Writes Per Day (DWPD) | 0.68 |
SSD Endurance | 500 TB |
Internal Data Rate | 3100 MBps (read) / 550 MBps (write) |
Maximum 4KB Random Write | 40000 IOPS |
Maximum 4KB Random Read | 205000 IOPS |
Reliability | |
MTBF | 1,800,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^17 |
Expansion & Connectivity | |
Compatible Bay | M.2 22110 |
Power | |
Power Consumption | 3.7 Watt (read) , 3.4 Watt (write) , 2 Watt (idle) |
Miscellaneous | |
Compliant Standards | VCCI, BSMI, FCC, RoHS, KC, RCM |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 85 °C |
Compatibility Information | |
Designed For | Synology SA3400, SA3600 , Synology Disk Station DS1618+, DS1819+, DS2419+, DS3018xs , Synology RackStation RS2818RP+, RS820+, RS820RP+ |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
