tado Additional Smart Radiator Thermostat - Vertical
LIMITED TIME OFFER
PRICE DROP
USUALLY £64!
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ideal for communal heating
  • More comfort
  • Type: Radiator thermostat
  • Compatible With: Alexa, Google Assistant, IFTTT, Siri
  • Stock Status: Clearance
Product codes
Bundle deals (1)
TP LINK KASA SMART WIFI POWER STRIP
= £63.98
Save £10.00
tado° Smart Radiator Thermostat (vertical mounting) - Add-on for Multi-room Control, intelligent heating control
The Smart Radiator Thermostat uses your phone’s location to control a room radiator. It turns the heating down when no one is home and starts to pre-heat when it detects the first person returning.
If you already have a Smart Radiator Thermostat - Starter Kit or a Smart Thermostat - Starter Kit (v3) with a Internet Bridge then you can use several Smart Radiator Thermostats to control multiple radiators and zones independently from one another.
What´s in the Box?
2 AA batteries
3 adapters
The Smart Radiator Thermostat in your tado° setup
The Smart Radiator Thermostat - Starter Kit forms the basis of your setup as it contains the Internet Bridge to connect your devices to the internet. The Smart Radiator Thermostat communicates via radio with the Internet Bridge and other devices.
Smart control of your radiators even if you do not have your own boiler.
More comfort
Individually control multiple radiators for maximum comfort.
Overview in app
Manage all zones and settings within the tado° app.
Compatibility
Smart Radiator Thermostat - Manage single or multiple radiators in your home if you have central heating or district heating.
Smart Thermostat + Smart Radiator Thermostats - If you have your own boiler we recommend using your Smart Radiator Thermostat with the Smart Thermostat to maximise your energy savings.
Self install
It's easy to install the Smart Radiator Thermostat yourself. Simply unscrew the old radiator thermostat and install the Smart Radiator Thermostat with the help of the Starter Kit adapter. Don’t worry, water cannot leak during installation.
tado° energy savings guarantee
Our promise
Not sure if tado° works for you? You can now enjoy a risk-free trial: If at any point you are not convinced, or tado° hasn’t saved enough during the first year, you may return the product and get a full refund.
Requirements:
• Applies to all heating products purchased after September 1 2016. The Smart AC Control, Smart Thermostat Starter Kit (v2) and the Connector kit (v1) products are excluded.
• copy of original receipt (tado° or retail partner)
• date of purchase not earlier than 12 months ago
• minimum of 6 months use
• shipment of complete and undamaged products
• it is not required to provide any additional documentation (bills etc.) regarding energy consumption. We trust you!
This guarantee is provided by tado. Any questions, please contact tado: https://www.tado.com/gb/heatingcontrol-savings#energy-savings-guarantee.
Product Description tado° Smart Radiator Thermostat
Connectivity Wireless
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
tado Additional Smart...
£39.00
