tado Additional Smart Thermostat
FREE DELIVERY
£99.00
Delivery:
Notify me
Key features
  • Saves energy
  • Efficiently manages your home temperature
  • Type: Thermostat
  • Compatible With: IFTTT, Alexa, Google Assistant
Product codes
The tado° Additional Smart Thermostat uses the intelligence of the web to offer you a high level of comfort while ensuring that no energy goes to waste.
This is an additional product of the tado° Starter Kits. You can add additional Smart Thermostats to your setup to control multiple rooms or zones independently from one another.
How tado° controls your heating
The Smart Thermostat and the Smart Radiator Thermostats connect to the internet and control your heating system or radiators.
Location-based control - The tado° Smart Thermostat automatically turns down your heating when the last person leaves home and begins to warm up again when it detects the first person returning.
The tado° app - With the tado° app on the residents’ smartphones, tado° detects how far they are away from home and sets the temperature accordingly. You can also manually control your heating.
Integrations
The new product suite offers several integration possibilities, such as Apple HomeKit, Google Home, Amazon Echo, and IFTTT.
Make tado° part of your connected home and create scenes with Apple HomeKit. Use Siri, Google Assistant or Amazon Echo to voice control your heating and create Applets with IFTTT to connect with other applications and smart devices.
Thermostat
The Smart Thermostat can be automatically controlled via the location of your smartphone as well as manually, by schedule or on the device itself.
LED matrix display - shows current temperature and settings
Touch arrows - to manually change the temperature and other settings
Button - to activate the display, scroll through the settings and make changes
The Smart Thermostat connects to the internet via the Internet Bridge that’s part of your Starter Kit (not included in this package).
Use your phone to control your heating across multiple rooms with this additional tado° smart thermostat. Used in conjunction with the tado° smart thermostat starter kit v3 (sold separately), you can set up multiple zones in your house for the perfect temperature in individual areas. It’s simple to change the settings using the app, or you can even sync it to a smart speaker for simple voice commands. It’s compatible with both combi boilers and boilers with a separate hot water tank, with an easy DIY installation so you can get started straight away.
Product Description tado° Smart Thermostat - Add-on - thermostat - matt white
Product Type Thermostat
Functions Control heating systems
Power Source Battery
Connectivity Wireless
Frequency Band 868 MHz
Supported Host Device OS iOS, Android, Windows Phone
Display LED
Colour Matt white
Dimensions (WxDxH) 10.4 cm x 1.9 cm x 10.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£99.00
Notify me
