tado Smart Radiator Thermoastat - Quattro Pack - Vertical
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Ideal for communal heating
  • More comfort
  • Stock Status: In Stock
Product codes
The Smart Radiator Thermostat uses your phone's location to control a room radiator. It turns the heating down when no one is home and starts to pre-heat when it detects the first person returning.
If you already have a Smart Radiator Thermostat - Starter Kit or a Smart Thermostat - Starter Kit of any version (V2/V3/V3+) then you can supplement these with additional Smart Radiator Thermostats to independently control multiple radiators.
Self install
It's easy to install the Smart Radiator Thermostat yourself. Simply unscrew the old radiator thermostat and install the Smart Radiator Thermostat with the help of the Starter Kit adapter. Don’t worry, water cannot leak during installation.
Product Description tado° Smart Radiator Thermostat - vertical - radiator thermostat
Product Type Radiator thermostat
Packaged Quantity 4 (specifications are for single item)
Functions Control heating systems
Power Source Battery
Intelligent Assistant Google Assistant, Alexa
Connectivity Wireless
Frequency Band 868 MHz
Thermostat LED
Colour Matt white
Dimensions (WxDxH) 5.2 cm x 5.2 cm x 7.8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
tado Smart Radiator Th...
£229.99
