tado Smart Radiator Thermostat - Quattro Pack - Vertical
33 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Works with a tado° Starter Kit and provides room-by-room scheduling and control from the tado° app
  • Easy to self-install when replacing an existing Thermostatic Radiator Valve (TRV)
  • Save energy by only heating the rooms you are using
  • Achieve your perfect temperature in every room
  • Comes with the tado° Energy Savings Guarantee - save on your heating bills within 12 months or get your money back!
  • Type: Radiator thermostat
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
The smart way to control your heating in individual rooms
Never heat your whole home again! tado° Smart Radiator Thermostats can replace your existing thermostatic radiator valves and provide room-by-room scheduling and control, so you can enjoy greater comfort and improve the efficiency of your heating system.
To benefit from tado° Smart Radiator Thermostats, you must also install a tado° Starter Kit.
Easy to install
This product can be easily self-installed - simply unscrew your existing thermostatic radiator valve, replace this with a tado° Smart Radiator Thermostat (using one of the 6 adaptors provided if required), and add the device in your tado° app.
Easy to use
The highly rated tado° app enables you to individually schedule and control each Smart Radiator Thermostat from anywhere, as well as providing insights and reports about the climate of individual rooms and showing you the energy savings made by tado°.
tado° is also compatible with Amazon Alexa, Apple HomeKit and Google Assistant, meaning you can control your heating in each room where you have a Smart Radiator Thermostat, using your voice, as well as integrating them into routines with your other smart home devices.
tado° Smart Radiator Thermostats are available to purchase in single, duo and quattro packs.
In the box:
- 4 x tado° Smart Radiator Thermostat
- 4 x 2 AA batteries
- 4 x Set of adaptors
Product Description tado° Smart Radiator Thermostat - vertical - radiator thermostat
Product Type Radiator thermostat
Packaged Quantity 4 (specifications are for single item)
Functions Control heating systems
Power Source Battery
Intelligent Assistant Google Assistant, Alexa
Connectivity Wireless
Frequency Band 868 MHz
Thermostat LED
Colour Matt white
Dimensions (WxDxH) 5.2 cm x 5.2 cm x 7.8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
tado Smart Radiator Th...
£229.99
