tado Smart Radiator Thermostat Starter Kit - Horizontal Kit
Product codes
Smart Radiator Thermostat - Starter Kit - Horizontal Mounting
Introducing our new Smart Radiator Thermostats: More comfort, better control and platform connectivity.
You don’t have your own boiler but have radiators?
With our new multi-room control you can save even more on your heating costs and make life more comfortable. The intuitive interface of the Smart Radiator Thermostats and the new Smart Schedules in the app make control of your heating even easier.
If you already have a Smart Thermostat - Starter Kit including the Internet Bridge, then you only need Smart Radiator Thermostats, not the Smart Radiator Thermostat - Starter Kit.
What´s in the Box?
2 Smart Radiator Thermostats, Internet Bridge, USB cable, connectors, ethernet cable, 2x 2 AA batteries, 3 different adapters per thermostat.
Integrations
The new product suite offers several integration possibilities, such as Apple HomeKit, Google Home, Amazon Echo, and IFTTT.
Make tado° part of your connected home and create scenes with Apple HomeKit. Use Siri, Google Assistant or Amazon Echo to voice control your heating and create Applets with IFTTT to connect with other applications and smart devices.
Setup
Heating control with the Smart Radiator Thermostat - Starter Kit
The included Internet Bridge connects via the router to the internet. The Smart Radiator Thermostats communicate by radio with the Internet Bridge.
Geolocation control:
tado° uses your phone’s location to control your heating. It saves when everyone is away and pre-heats when it detects the first person returning home.
More control:
tado° lets you know how warm your home is, when the heating is on and gives you control from wherever you are.
Save money:
tado° saves energy and heating costs.
Report overview:
The report shows you your home temperature throughout the day and when your heating was on.
Inclusion of weather forecasts:
tado° automatically adapts your heating to the current weather in order to heat most efficiently.
Effortless:
Easy to install, intuitive to use and fully automatic. tado° adjusts the heating to fit your lifestyle.
Incorporates building characteristics:
Every house is different, tado° gets to know your home to optimise your heating.
Flexible use:
tado° adapts to your preferences: using automated location-based heating, schedules or manual control.
Control from anywhere:
Full access from anywhere and anytime via smartphone, tablet or computer.
Compatibility
Work with both your own boiler and with district heating.
Smart Thermostat + Smart Radiator Thermostats:
If you have your own boiler, we recommend using the Smart Thermostat for central control in addition to individual radiator control. This will save even more energy.
Self install
It’s easy to install the Smart Radiator Thermostat - Starter Kit yourself. Simply unscrew the old radiator thermostat and install the Smart Radiator Thermostat with the help of one of the included adapters. Don’t worry, water can not leak during installation.
tado° energy savings guarantee
Our promise
Not sure if tado° works for you? You can now enjoy a risk-free trial: If at any point you are not convinced, or tado° hasn’t saved enough during the first year, you may return the product and get a full refund.
Requirements:
• Applies to all heating products purchased after September 1 2016. The Smart AC Control, Smart Thermostat Starter Kit (v2) and the Connector kit (v1) products are excluded.
• copy of original receipt (tado° or retail partner)
• date of purchase not earlier than 12 months ago
• minimum of 6 months use
• shipment of complete and undamaged products
• it is not required to provide any additional documentation (bills etc.) regarding energy consumption. We trust you!
This guarantee is provided by tado. Any questions, please contact tado: https://www.tado.com/gb/heatingcontrol-savings#energy-savings-guarantee.
Product Description tado° Smart Radiator Thermostat Starter Kit - radiator thermostat
Product Type Radiator thermostat
Sensor Type Temperature, humidity, ambient light
Functions Control heating systems
Power Source Battery, power adapter
Package Content 2 x radiator thermostats, bridge
Connectivity Wireless
Frequency Band 868 MHz
Thermostat LED
Colour Matt white
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
tado Smart Radiator Th...
