tado Smart Radiator Thermostat Starter Kit V3+ Vertical
FREE DELIVERY
Key features
  • LED display shows current settings
  • Control knob to manually change the temperature
  • Save up to 31% on your heating bills!
  • Type: Radiator thermostat
  • Compatible With: Alexa, Google Assistant
  • Stock Status: Clearance,
    Used stock also available below
Product codes
tado° Smart Thermostats V3+ - Smarter heating for more comfort and effortless savings
tado° is your Climate Assistant designed to make your live more comfortable by taking care of your comfort and savings at home. Get easy access and control of your heating system via the tado° app from anywhere, anytime. The unique skills of the Climate Assistant enable you to save up to 31% on your heating bill and achieve a healthier climate at home:
- Geofencing
- Open Window Detection
- Weather Adaptation
- New V3+: Air Comfort
- Smart Schedule
- New V3+: Auto-Assist: For even more comfort you can automate Geofencing and Open Window Detection (monthly subscription bookable in app, only £2.99/month, cancel anytime)
Additional features:
- Multi-room Control
- Hot water control
- Insightful reports
Seamless Smart Home integration & voice control with Amazon Alexa, Apple HomeKit, Google Assistant, & IFTTT.
What´s in the box?
tado° Smart Radiator Thermostat
2 AA batteries
Set of adapters
tado° Internet Bridge
UK power adapter
EU power adapter
USB cable
Ethernet cable
The smart way to control your heating. tado° is your Climate Assistant that ensures a comfortable and healthy climate, whilst considerably reducing your energy consumption. The intuitive smartphone app and smart home integrations enable you to control your heating from anywhere and more efficiently than ever before. It works with voice assistants too, so when you’re snuggled up on the sofa, you won’t even need to reach for your phone to make your home all toasty. Plus, it’s compatible with both combi boilers and models with separate tanks, and this model also comes with the hub, so you can get started straight away.
Smart Skills
Tado° detects open windows, incorporates weather forecasts and helps you adjust the temperature based on your location. Tado° also lets you set heating and cooling schedules to suit your routine. Tado° gives you insights into the temperature and humidity in your home. It advises you on how to keep the air in your home healthy. Tado puts you in control of your heating or air conditioning anytime, from anywhere via the app.
Product Description tado° Smart Radiator Thermostat (Vertical) - v3+ - Starter Kit - radiator thermostat - matt white
Product Type Radiator thermostat
Functions Control heating systems
Integrated Sensors Humidity, temperature
Power Source Battery
Internet of Things (IoT) Platform Apple HomeKit
Intelligent Assistant Google Assistant, Alexa
Package Content Bridge
Connectivity Wireless
Frequency Band 868 MHz
Display LED
Colour Matt white
Dimensions (WxDxH) 5.2 cm x 5.2 cm x 7.8 cm
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: DX8Z 046123
£103.09
product
Ref: DX8Z 046123
Accessories
Packaging
Functional
Software
Manuals
£103.09
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
