tado° Smart Thermostats V3+ - Smarter heating for more comfort and effortless savings
tado° is your Climate Assistant designed to make your live more comfortable by taking care of your comfort and savings at home. Get easy access and control of your heating system via the tado° app from anywhere, anytime. The unique skills of the Climate Assistant enable you to save up to 31% on your heating bill and achieve a healthier climate at home:
- Geofencing
- Open Window Detection
- Weather Adaptation
- New V3+: Air Comfort
- Smart Schedule
- New V3+: Auto-Assist: For even more comfort you can automate Geofencing and Open Window Detection (monthly subscription bookable in app, only £2.99/month, cancel anytime)
Additional features:
- Multi-room Control
- Hot water control
- Insightful reports
Seamless Smart Home integration & voice control with Amazon Alexa, Apple HomeKit, Google Assistant, & IFTTT.
What´s in the box?
2 sticky pads
3 AAA batteries
2 wall mounting screws
2 wall plugs
Labels for wiring
tado° Internet Bridge
UK Power supply
EU Power supply
USB cable
Save up to 31% of your heating cost with tado
Geofencing
Never heat an empty home. Based on the residents' location, tado° helps you save when nobody is home.
tado° recognizes an open window, allowing the heating to be turned down and thereby preventing unnecessary heating.
Weather Adaption
Making use of natural heat to save energy; by considering local weather forecasts, tado° knows when to turn down the heating because the sunshine will warm up your home.
Air Comfort
tado° helps you achieve a healthier indoor climate, with insights and specific advice, e.g. when, and for how long, to open the windows, or if a room has a risk of developing mold.
Insightful reports
See the temperature & humidity profile, heating & weather activity, when the windows were opened, and how much you have saved.
Boiler Health Monitoring (not for Smart Radiator Thermostat)
tado° keeps track of the status of your boiler, notifies you when there is a problem, gives you suggestions on how to resolve it, and provides a qualified engineer if needed.
Multi Room Control
Add further tado° thermostats to control additional zones or rooms individually. Combine central and individual room radiator control for maximum efficiency.
tado° energy savings guarantee
We at tado° believe in our products and guarantee that they will help you save energy and costs. If at any point you are not convinced, or tado° hasn’t saved enough during the first year, you may return the product and get a full refund.
Eligibility
- Applies to all heating products purchased or rented after September 01 2016. Smart AC Control, Smart Thermostat Starter Kit (v2), Connector Kit (v1) are excluded.
- Date of purchase not earlier than 12 months ago.
- Minimum of 6 months use.
- Ship your tado° to tado° Germany - the detailed process you find at www.tado.com/eg
- It is not required to provide additional documentation (bills etc.) regarding energy consumption. We trust you!
For further information, please have a look at www.tado.com/eg
