tado Starter Kit - Wireless Smart Thermostat V3+
18 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Wireless Smart Thermostat that works with combi-boilers and those with a hot water tank
  • Schedule and control your heating and hot water from anywhere through the tado° app
  • Packed full of energy saving skills, including Geofencing - never heat an empty home!
  • Comes with the tado° Energy Savings Guarantee - save on your heating bills within 12 months or get your money back!
  • Type: Thermostat
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
The smart way to control your heating and hot water
Replace your old thermostat with the tado° Smart Thermostat with Hot Water Control and experience a new level of comfort and control, whilst saving energy and reducing your heating bills.
Easy to install
This Starter Kit can be self-installed and tado° provides easy to follow instructions based on your current heating set-up.
The tado° Smart Thermostat with Hot Water Control works with combi-boilers and those with a hot water tank. It includes the tado° Extension Kit, which allows the Smart Thermostat to operate wirelessly, meaning you can position it wherever you desire.
Easy to use
The highly rated tado° app enables you to schedule and control your heating and hot water from anywhere, as well as providing insights and reports about your home climate and showing you the energy savings made by tado°.
tado° is also compatible with Amazon Alexa, Apple HomeKit and Google Assistant, meaning you can control your heating and hot water with your voice, as well as integrating it into routines with your other smart home devices.
Save up to 31% on your heating bills!
tado° comes with an Energy Savings Guarantee - if you are not satisfied that tado° has saved you energy in the first 12 months, simply return the product to tado° and get your money back, no questions asked!
tado° increases the efficiency of your heating system, as well as improving your comfort at home with the help of its smart Skills:
- Geofencing(1) - tado° uses your phone’s location to alert you to turn the heating off when the last person leaves and preheat your home back to a comfortable temperature for your return
- Open Window Detection(1) - lets you effortlessly turn off your heating for a short period when it notices open windows or doors
- Weather Adaptation - saves you money on warmer days and ensures your comfort is maintained on colder days
- Air Comfort - gain insights about the freshness of the air inside your home, as well as outside air quality information at your postcode
- Smart Schedule - fully personalise each day to your lifestyle, plus set your "Minimum Away Temperature" and preheat settings, ensuring you can find your perfect balance between comfort and savings.
(1) For even more comfort you can automate these Skills with Auto-Assist (available in-app, £2.99/month or £24.99/year). Without subscription you are alerted via a push notification to turn off your heating.
In addition, should you wish to schedule and control each room individually either now or in the future, tado° offers their Smart Radiator Thermostats for a whole home heating solution. Finally, tado° is also compatible with Opentherm and many other digital connections within combi-boilers, enabling modulating boiler control and even greater heating efficiency.
In the box:
Starter Kit:
tado° Smart Thermostat, tado° Internet Bridge, 2 sticky pads, 3 AAA batteries, 2 wall mounting screws, 2 wall plugs, Labels for wiring, UK Power supply, USB cable, Ethernet cable
Extension Kit:
tado° Extension Kit. Cable, Luster terminal, Euroblock plug, RAST5 plug, 2 wall mounting screws, 2 wall plugs, Labels for wiring
Product Description tado° Smart Thermostat - v3+ - Starter Kit - thermostat
Product Type Thermostat
Functions Control heating systems
Power Source Battery, power adapter
Internet of Things (IoT) Platform Apple HomeKit
Intelligent Assistant Google Assistant, Alexa
Package Content Thermostat, bridge
Connectivity Wireless
Frequency Band 868 MHz
Thermostat LED
Colour Matt white
Localisation United Kingdom
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
tado Starter Kit - Wir...
£199.99
