This protective cover is perfect for those that play rough and want reliable protection. The combination of rigid plastic and shock-absorbing silicone ensures your machine is always protected while the built in screen cover keeps your touchscreen protected and scratch free.
Product Description | Tech air - protective case for tablet | Product Type | Protective case for tablet | Screen Size Compatibility | 10.1" | Dimensions (WxDxH) | 18.5 cm x 2 cm x 27.5 cm | Weight | 380 g | Material | Silicone, polycarbonate | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | Samsung Galaxy Tab A (2016) (10.1 in) |
General | |
Width | 18.5 cm |
Depth | 2 cm |
Height | 27.5 cm |
Weight | 380 g |
Rugged | Yes |
Colour | Black |
Carrying Case | |
Type | Protective case |
Recommended Use | For tablet |
Protection | Shockproof, scratch-resistant |
Inner Dimensions | 15.53 cm x 0.82 cm x 25.42 cm |
Included Accessories | Protective screen |
Cover Features | Stand function |
Manufacturer Warranty | |
Service & Support | Lifetime |
Compatibility Information | |
