Thrustmaster Hotas Warthog Joystick and Throttle for PC
DUAL THROTTLE CONTROL & 19 ACTION BUTTONS!
Key features
  • Compatible with the HOTAS Cougar (and vice-versa)
  • Replica shape of the A-10C flight stick
  • Detachable metal plate for desk- or cockpit-style use
  • Realistic pressure on buttons and trigger
  • 19 action buttons in total + one 8-way "point of view" hat
  • USB connector and upgradeable firmware
  • Super-stable, weighted joystick
Product codes
The Hotas Warthog™ is an U.S. Air Force A-10C attack aircraft HOTAS™ (Hands On Throttle And Stick) replica joystick high end system including:
Dual Replica THROTTLES
Software suite: T.A.R.G.E.T (Thrustmaster Advanced pRogramming Graphical EdiTor)
Replica JOYSTICK
Replica A-10 Flight Stick
Innovative new H.E.A.R.T HallEffect AccuRate Technology:
- 3D magnetic sensors (Hall Effect) on the stick: enjoy surgical precision that stays razor-sharp over time
- 16-bit resolution (65536 x 65536 values)
- 5 coil spring system: firm, linear and fluid tension, with no dead zones
USB connection with upgradeable firmware
Super-stable, weighted base (over 3kg)
New detachable handle, crafted entirely of metal:
- also compatible with HOTAS COUGAR™ handle (and vice-versa)
- new replica shape
- detachable metal plate for desk- or cockpit-style use
- new, realistic pressure on buttons and trigger
- 19 action buttons in total + one 8-way "point of view" hat:
. 1 x 8-way "point of view" hat
. 2 x 8-way hats
. 1 x 4-way hat with push button
. 1 x metal dual trigger
. 2 x push buttons
. 2 x pinkie push buttons
- 3D magnetic sensors (Hall Effect) on the 2 throttles: enjoy surgical precision that stays razor-sharp over time
- 14-bit resolution (16384 values) on each throttle
Dual throttles, featuring:
- metal hand rest
- locking system
- adjustable friction system: firm, linear and fluid tension, with no dead zones
- realistic IDLE detent with "Pull & Push" system
- realistic and disengageable AFTERBURNER detent with "Pull & Push" system
- realistic pressure on buttons and switches
- 17 action buttons in total + 1 mouse hat with push button + one 8-way "point of view" hat:
. 1 x mouse hat with push button and 3D magnetic sensor (Hall Effect)
. 1 x 8-way hat
. 1 x push button
. 1 x 3-position switch (2 momentary + 1 permanent)
. 2 x 3-position switches (3 permanent)v . 1 x 3-position switch (1 momentary + 2 permanent)
Replica Control Panel
Weighted base (over 3kg) incorporated underneath the throttles
Backlit functions
5 programmable LEDs
Realistic pressure on buttons and switches
15 action buttons in total + 1 TRIM wheel:
. 1 x TRIM wheel
. 2 x push buttons
. 5 x 2-position switches (2 permanent)
. 2 x 3-position switches (1 momentary + 2 permanent)
SOFTWARE SUITE: T.A.R.G.E.T (Thrustmaster Advanced programming graphical editor)
To test, configure and program Thrustmaster® controllers: HOTAS WARTHOG™, MFD Cougar, HOTAS Cougar™ and T.16000M
Uses the "Drag and Drop" principle
Multiple programming levels: Basic, Advanced and Script
Thrustmaster HOTAS Warthog - joystick and throttle - wired
Joystick and throttle
Wired
Dual throttle control, H.E.A.R.T HallEffect AccuRate Technology
PC
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Thrustmaster Hotas War...
