The joystick with detachable throttle control and direct configuration for immediate takeoff!! Entirely Programmable PC and PS3™!
Unique: Plug & Play for ultra-simple and fast installation with all functions pre-configured for immediate takeoff (without worrying about configuration)
Weighted base for greater stability
Configurations by default:
Exclusive "PRESET" button": to switch, while playing, instantly from one programme to another
Detachable, real-size, ergonomically-designed throttle control
Internal memory: to save all of your programming, even with the joystick disconnected
Dual-system aerodynamic control: by rotating handle (with integrated blocking system) or by progressive tilting lever
Exclusive "MAPPING" button: all functions may be instantly switched around between each other
High-precision joystick with adjustable resistance
Programmable: the 12 buttons and 5 axles are entirely programmable.
Wide hand-rest for optimal comfort
Trigger for brakes (civil flight) or for rapid fire (military flight) + multi-directional hat (panoramic view)
Product Description | Thrustmaster T-Flight Hotas X - joystick - wired | Product Type | Joystick | Connectivity Technology | Wired | Buttons Qty | 12 | Controls | Hat switch, throttle | Features | Handle rotation | Designed For | PC, Sony PlayStation 3 |
General | |
Buttons Qty | 12 |
Interface | USB |
Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | Plug and Play |
Compatibility Information | |
