Thrustmaster TMX Pro Force Feedback Racing Wheel & Pedals...
FREE DELIVERY
Thrustmaster TMX Pro Force Feedback Racing Wheel & Pedals (Xbox One/PC)
£219.99
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Perfectly realistic wheel
  • Maximum racing comfort
  • Extreme racing precision
  • Type: Wheel and pedals set
  • Wired / Wireless: Wired
  • Compatibility: Microsoft Xbox One, PC
  • Stock Status: In Stock
Product codes
Documents
Feel like you're behind the wheel of a high-powered race car with this Thrustmaster TMX Pro racing wheel for Xbox One and PC. Featuring a competition size of 28cm and a 900-degree force feedback system that brings every in-game bump to life, this Pro racing wheel includes the T3PA wide 3-pedal set with progressive resistance brake pedal.
Included: T3PA 3-pedal pedal set
The TMX is bundled with the three-pedal Thrustmaster T3PA pedal set, whose pedals and internal structure are all 100% metal. The T3PA is fully adjustable (spacing, angle and gas pedal with an adjustable height setting), and users can even adjust the push force independently for each pedal. The optional Conical Rubber Brake Mod is also included, allowing for an authentic feel with ultra-progressive resistance at the end of the pedal’s travel.
The wheel features reinforced rubber-coated grips. Sequential gear shifts are facilitated by the two large (5"/13 cm tall), 100% metal wheel-mounted sequential paddle shifters.
11 inch/28 cm diameter racing wheel, with an ergonomic design perfectly adapted for all driving games (GT, Formula 1, NASCAR, rally, etc.).
A rotation angle adjustable from 270 to 900 degree allows gamers to race in all vehicles with unrivalled realism. High-precision racing wheel: optical reading with 12-bit resolution (i.e. 4,096 values on the wheel’s steering axis).
Realistic Force Feedback effects
Experience every racing sensation to the fullest thanks to the realistic Force Feedback – the road or track's relief, loss of tire grip, braking, bumps and impacts, etc. A smooth, precise and silent racing wheel, featuring a mixed belt-pulley and gears system.
Xbox One certified embedded software
Official embedded software: the racing wheel is automatically recognized by the Xbox One, compatible in the console’s menus and compatible with all Xbox One racing games supporting racing wheels.
All controls within easy reach
Never take your hands off the wheel, thanks to the built-in official buttons for Xbox One: Xbox Guide button, View and Menu. Easily access all social functions, switch between the game and the system, navigate through the console's menus, etc.
Compatible with Thrustmaster TH8A* shifter
Compatible with the Thrustmaster TH8A* shifter. Comes with 2 included shift-plates: "H"-pattern (7+1) and Sequential (+/-). *Sold separately.
Product Info
  • Officially designed for instant plug-and-play use with the Xbox One console and is compatible with Windows 10, 8, 7, and Vista via downloadable drivers
  • Includes the Thrustmaster T3PA wide 3-pedal set that features metal construction on the pedals and internal structure, adjustable pedals, and a brake pedal with progressive resistance
  • Realistic high-performance racing wheel measures 11" (28cm) in diameter and features a comfortable ergonomic design, perfectly adapted for Xbox One racing games that support a racing wheel
  • 900-degree force feedback system brings the on-screen action to life, letting you feel every hard brake, subtle bump, loss of tire grip, and change in road surface
  • Mixed-belt pulley and gears system delivers a smoother and more fluid experience than wheel sets that feature noisy helical gears
  • Metal ball-bearing axle gives the wheel set base a solid, sturdy, and durable build that will stand up to the rigors and stresses of competitive digital racing
  • Wheel rotation angle is adjustable to between 270 and 900 degrees so you can tailor it to your exact preferences
  • Equipped with 2 large, wheel-mounted sequential paddle shifters with full metal construction and integrated Tact switch
  • Built-in official Xbox One buttons and directional pad allow you to switch between the game and the system, navigate system menus, access social functions, and more
  • Compatible with the Thrustmaster TH8A shifter (sold separately)
Product Description ThrustMaster TMX PRO - wheel and pedals set - wired
Product Type Wheel and pedals set
Connectivity Technology Wired
Designed For PC, Microsoft Xbox One
Resources
The following resources are available for the Thrustmaster TMX Pro Force Feedback Racing Wheel & Pedals (Xbox One/PC)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Thrustmaster TMX Pro F...
£219.99
