Toshiba 1TB Canvio Alu 2.5" USB 3.0 Portable Hard Drive
Key features
  • Smart mobile storage
  • Back-ups made easy
  • Set-up made simple
Product codes
SOLID PORTABLE STORAGE
Store your essential data securely on the Canvio Alu, and access it quickly and easily through SuperSpeed USB 3.0.
With its elegant black aluminium casing you can stay stylish while you’re carrying important documents and media files. What’s more, the easy to use, inbuilt NTI backup software allows you to make regular automatic backups of 1TB of data, for added peace of mind.
Fast Transfer Speeds
Powered by new USB 3.0 technology, these portable hard drives are far faster than-but still compatible with-USB 2.0 technology. That's important for speedy transfer when organising your files.
Durable Elegance
With a sleek and solid aluminium casing, Canvio Alu series portable hard drives are not only stylishly designed, but also provide durable protection for your data. With a built-in shock sensor and ramp loading technology, the Canvio Alu will keep your data safe from life's bumps and scrapes.
Back-Up Software On-Board
Keep all your critical data and digital memories secure with NTI Backup Now EZ software. This intuitive pre-loaded tool automatically backs up and restores your files or folders - so you can worry less, and create more. What's more, you can schedule when and how often you want the backups to occur, and even arrange a complete system backup, for the ultimate combination of convenience and security.
Transfer with Ease
With the Canvio Alu, you can automatically transfer data using the automatic backup function. Alternatively, you can manually select which files to backup with ease by simply dragging-and-dropping files to and from your desktop or laptop, rearranging your important media and documents in seconds.
Product Description Toshiba Canvio Alu - hard drive - 1 TB - USB 3.0
Type Hard drive - external ( portable )
Capacity 1 TB
Form Factor 2.5"
Interface USB 3.0 (USB 2.0 compatible)
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Bus Powered by USB, NTFS formatted, aluminium enclosure
Power Source USB bus
Enclosure Colour Black
Dimensions (WxDxH) 75 mm x 113.5 mm x 12 mm
Weight 180 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Toshiba 1TB Canvio Alu...
