Toshiba 1TB Canvio Alu 3S - Silver - USB3.0 2.5" Portabl...
FREE DELIVERY
Toshiba 1TB Canvio Alu 3S - Silver - USB3.0 2.5" Portable HDD
Select:
  • 1TB
Key features
  • Smart mobile storage
  • Back-ups made easy
  • Set-up made simple
Product codes
Canvio Alu - Solid portable storage
Store your essential data securely on the Canvio Alu and access it quickly and easily through SuperSpeed USB 3.0. With its elegant aluminium casing you can stay stylish while carrying important documents and media files. What’s more, the easy to use inbuilt NTI backup software allows you to make regular automatic backups of data, for added peace of mind.
DURABLE ELEGANCE
With a sleek and solid aluminium casing, Canvio Alu series portable hard drives are not only stylishly designed but also provide durable protection for your data. Thanks to its built-in shock sensor and ramp loading technology the Canvio Alu will keep your data safe from life's bumps and scrapes.
HIGH TRANSFER SPEEDS
Powered by USB 3.0 technology, these portable hard drives are much faster than — but still compatible with — USB 2.0 devices, allowing for speedy transfer when organising your files.
BACKUP SOFTWARE ON-BOARD
Keep all your critical data and digital memories secure with NTI Backup Now EZTM software. This intuitive pre-loaded tool automatically backs up and restores your files or folders – so you can worry less and create more. What’s more, you can schedule when and how often you want the backups to occur and even keep a complete system backup, for the ultimate combination of convenience and security.
TRANSFER WITH EASE
With the Canvio Alu you can transfer data automatically using the automatic backup function. Alternatively, you can manually select which files to backup with ease by simply dragging-and-dropping them to and from your desktop or laptop, rearranging your important media and documents in seconds.
Toshiba Canvio Alu - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Bus Powered by USB, NTFS formatted, aluminium enclosure
Power Source
USB bus
Enclosure Colour
Silver
75 mm x 113.5 mm x 12 mm
180 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba 1TB Canvio Alu...
