Toshiba 1TB Canvio Connect II USB 3.0 2.5" Portable Hard...
Toshiba 1TB Canvio Connect II USB 3.0 2.5" Portable Hard Drive Blue
£57.78
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compact and anti-slip design for easy portability
  • USB-powered for easy plug-and-play operation
  • Internal shock sensor and ramp loading technology help protect your drive and data
  • Form Factor: 2.5"
  • Capacity: 1TB
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
The Canvio Connect II is a smart storage solution that will soon become your favourite data companion. Not only do you get up to 3 TB of portable storage, backing up your files also is a breeze, thanks to the pre-installed NTI® Backup Now EZ™ software. A NTFS driver for Mac is also included, so you can use the Canvio Connect II on both Windows PC and Apple Macintosh platforms. And all this is packed into a solid, stylish enclosure available in five colours that fit in the palm of your hand.
More terabytes, more colours
The go-anywhere Canvio Connect II puts up to 3 TB of external storage into the palm of your hand. The sleek, sturdy chassis comes in a variety of colours to match your style. It will soon become your favourite data companion.
SuperSpeed USB 3.0
Powered by USB 3.0 technology, these hard drives are far faster than—but still compatible with—USB 2.0 technology. That's important for speedy transfer when organising your files.
Complete backup soloution
The pre-loaded NTI® Backup Now EZ™ software provides comfortable and reliable file, folder, and full system backup and recovery.
Safeguard your data
Since life on the road can be rough and tumble, the Canvio Connect II has taken extra precautions to safeguard your data from shock. It includes an internal shock sensor and ramp loading technology to help keep your drive safe on the go.
Mac and PC
Because a NTFS driver for Mac is included, there are no worries with compatibility. Whether it's a PC or a Mac - or both - just plug in your Canvio Connect II and get instant access to your files.
Product Description Toshiba Canvio Connect II - hard drive - 1 TB - USB 3.0
Type Hard drive - external (portable)
Capacity 1 TB
Form Factor 2.5"
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Bus Powered by USB, NTFS formatted
Power Source USB bus
Enclosure Colour Blue
Dimensions (WxDxH) 7.8 cm x 10.9 cm x 1.4 cm
Weight 165 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba 1TB Canvio Con...
£57.78
