Toshiba 1TB Canvio Premium 2.5" Portable Hard Drive Dark...
LAST FEW REMAINING
PRICE DROP
Toshiba 1TB Canvio Premium 2.5" Portable Hard Drive Dark Grey
PRICE DROP!
Key features
  • High-quality aluminum design
  • Easily store, access and protect your files
Product codes
The Canvio Premium offers superiority in form and function. Its smooth, high quality aluminium design with diamond-cut edges makes it stand out from the crowd, while highly-specified features make it easier than ever to store and protect your files. Its sleek style makes it look at home sitting next to everything from notebooks to high-end desktop PCs, and with the supplied Type-A to Type-C USB adapter, more of those connections are possible.
Smart storage for all your files
Up to 3 TB housed in a stylish aluminium design with diamond-cut edges makes this drive a smart companion to any device, on your desk or on the move. To protect your Canvio Premium whilst on the move, a soft carry pouch is included.
Two USB types for extra connectivity
A small, neat Type-A to Type-C USB adapter is included, so you can connect to everything from notebooks to high-end desktop PCs.
Auto-backup software
Pre-loaded NTI® Backup Now EZ™ software automates file, folder, and full system backup and recovery for complete peace of mind.
Lock up your data
Stop unauthorised users from accessing your private information by locking your Canvio Premium with a unique password.
Easily switch between PC and Mac
Canvio Premium hard drives come with a NTFS driver for Mac®, allowing you to store and access files on both PC and Mac without reformatting.*
* Reformatting to HFS+ required for use with Apple® Time Machine® software.
Three year warranty
Toshiba design and build quality means we can confidently provide a three year warranty, to keep your investment protected for longer.
Product Description Toshiba Canvio Premium - hard drive - 1 TB - USB 3.0
Type Hard drive - external (portable) - password authentication, Bus Powered by USB, NTFS formatted
Capacity 1 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Password authentication, Bus Powered by USB, NTFS formatted
Power Source USB bus
Enclosure Colour Dark grey metallic
Dimensions (WxDxH) 78 mm x 13.5 mm x 109 mm
Weight 165 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba 1TB Canvio Pre...
