Toshiba 2TB Canvio Basics 2018 USB 3.0 2.5" Portable Har...
FREE DELIVERY
Toshiba 2TB Canvio Basics 2018 USB 3.0 2.5" Portable Hard Drive
£60.74
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Sleek profile design with a matte, smudge-resistance finish
  • Plug & Play - Easy to use with no software to install
  • Quickly add more storage capacity to your PC and other compatible devices
  • USB 3.0 and USB 2.0 compatible with no external AC power cord needed
  • Form Factor: 2.5"
  • Capacity: 2TB
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
Toshiba's Canvio Basics for the PC requires only a single step to start saving and transporting important files, plug it in. With no software necessary to install, the Canvio Basics portable hard drive offers a hassle-free, high capacity storage solution right out of the box.
A sleek solution with plenty of storage capacity for the growing amount of digital content, from photos and videos to music and documents, the Canvio Basics offers an intelligent combination of data protection, portability, and simplicity. The one plug ease-of-use is complemented by the drive's stylish design, courtesy of a glossy finish and soft, rounded edges. Despite its light weight design and diminutive size, the Canvio Basics can add peace of mind by keeping files safe with its internal shock sensor and Ramp Loading technology.
Beyond its technical capabilities, the practicality of the Canvio Basics portable hard drive is evident in the drive's pocket-sized form factor which not only makes it easy to carry but also conforms to Toshiba's environmental efforts to reduce materials used in production. In addition, the Canvio Basics' packaging is made from 100 percent recyclable materials.
Product Description Toshiba Canvio Basics - hard drive - 2 TB - USB 3.0
Type Hard drive - external (portable) - NTFS formatted, LED power indicator
Capacity 2 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features NTFS formatted, LED power indicator
Power Source USB bus
Enclosure Colour Black
Dimensions (WxDxH) 78 mm x 109 mm x 14 mm
Weight 149 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba 2TB Canvio Bas...
£60.74
