THE IDEAL MATCH FOR YOUR MAC
The Canvio Premium for Mac has a high quality diamond-cut aluminium design that will complement your high-end Mac devices. It also offers Mac-friendly functionality, with Apple® Time Machine® compatibility out of the box, and its own password tool. You can connect to all your Mac devices, using the small and neat Type-A to Type-C USB adapter, and access your files in more places, thanks to pocket-size portability, remote access capabilities, and an extra 10 GB of cloud storage.
THE IDEAL MAC COMPANION
A smart aluminium design with diamond-cut edges makes this drive a perfect match to any modern Mac device, giving you up to 3 TB of storage at your desk or on the move. To protect your Canvio Premium for Mac whilst on the move, a soft carry pouch is included.
EXTRA USB FLEXIBILITY
USB 2 and 3 is supported and a small, neat Type-A to Type-C USB adapter is included, giving you the flexibility to connect to more devices.
PLUG IN AND GO
No need to reformat, Canvio Premium for Mac drives are ready to use right away, with full Apple® Time Machine® compatibility.
EXTRA SECURITY
Protect your private data from unauthorised users using the supplied Canvio password tool for Mac.
REMOTE ACCESS PLUS AN EXTRA 10GB IN THE CLOUD
Store an extra 10 GB of data securely in the cloud and access it on the go. You can also remotely access all the data on your Canvio Premium using software on mobile devices.
THREE YEAR WARRANTY
We have such confidence in our design and build quality, we’re happy to include a three year warranty, so you can buy and use with confidence too.
