Toshiba's 7200 rpm 3.5-inch HDD series is optimized for use in power-friendly consumer and commercial desktop computers, gaming PCs and external HDDs. The DT01ACA200 offers large capacity and uses advanced format and leverages a best-in-class power management technology. In addition, this desktop drive provides up to 16% idle power savings over the previous model. The 6 Gbps SATA interface drives deliver 7200 rpm performance. The HDD is designed to allow manufacturers to leverage the benefits of the latest components and operating systems to deliver high-performance, high-capacity, power-efficient systems.
2TB capacity
7200 RPM performance
For use in consumer and commercial computers
6 Gb/s SATA Interface
Halogen-free design
Specification
Capacity: 2TB
Form factor: 3.5 inch
Interface type: Serial ATA
Rotational speed: 7,200 rpm
Supported interface standards: ATA-8 Serial ATA 3.0
S.M.A.R.T.: The SMART command set is supported.
Transfer rate - SATA (Host) max.: 6.0 Gbit/s
Buffer size: 64 MByte
Physical
Bytes/sector (Host): 512
Bytes/sector (Disk): 4096 kByte
Access
Single track seek time (read): 0.5 ms
Single track seek time (write): 0.6 ms
Reliability
Load/Unload: 300,000 Times
Non-recoverable error rate: 1 error per 1014 read
Power Consumption
Read (Random): 6.4W
Write (Random): 6.4w
Idle: 5.2w
Stand-by: 1.0w
Sleep: 1.0w
Mechanical Specifications
Drive width: 101.6 mm
Drive height: 26.1 mm
Drive depth: 147 mm
Weight (max.): 0.680 kg
Temperature, Vibration & Shock
Operating Temperature: From 0 °C to 60 °C
Non-operating Temperature: From -40 °C to 70 °C
Operating Vibration: 0.67 G, with 5 - 500 Hz
Non-operating (Maximum) Vibration: 1.04 G, with 2 - 200 Hz
Operating Shock: 70 G, with 2 ms half sine wave
Non-operating shock: 300 G, with 2 ms half sine wave
Support
2 Year Manufacturer Warranty
