Toshiba 3TB Canvio Advanced USB 3.0 2.5" Portable Hard D...
Toshiba 3TB Canvio Advanced USB 3.0 2.5" Portable Hard Drive Red
£102.01
Delivery:
Standard: 1-3 working days
Key features
  • Compact, easy-to-hold design with a high gloss finish
  • A lot of storage capacity to store your growing files and content
  • Toshiba Storage Backup Software - easily back up your photos, music, videos
  • Toshiba Storage Security Software - helps prevent unauthorized access to your data
  • USB 3.0 and USB 2.0 compatible with no external AC power cord needed
Product codes
The Canvio Advance portable hard drive allows creators to do what they do best - anywhere their lives take them - offering high storage capacity, 24/7 access to your stored content and the time-tested reliable performance they need.
Whenever and wherever creativity strikes, Canvio Advance offers the space to create. The Toshiba Canvio Advance provides a lot of storage so you can store thousands of pictures, videos, music, or a variety of large files on a small 2.5" portable drive.
The Toshiba Canvio Advance features a minimalist design as well as clean edges, a sleek, high-gloss surface, and color options to inspire you - it's your life, your style, your speed.
Keep your files safe and secure with features such as password protection and scheduled backup. Work at the speed of inspiration with the lightning fast transfer speeds of Canvio Advance. With USB 3.0 you'll be able to transfer and backup files on the go while powering the drive through your laptop's USB connection.
These durable external hard drives are built to Toshiba's world-class quality standards. Access all of your stored content 24/7 easily from the Canvio Advance hard drive.
Toshiba Canvio Advance - hard drive - 3 TB - USB 3.0
Hard drive - external (portable)
3 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
NTFS formatted
Power Source
USB bus
Enclosure Colour
Glossy piano red
7.8 cm x 10.9 cm x 1.9 cm
210 g
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Toshiba 3TB Canvio Adv...
£102.01
